Old 03-22-2021, 08:26 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Starter stuck
Went to start the 30 & the starter stuck in the run position, Good thing I forgot to turn the key on. Jump out of the car & hit the starter with a rubber mallet & it stop. What Happen ??
Lefthander1930
Lefthander1930 is offline   Reply With Quote
Old 03-22-2021, 08:47 PM   #2
Brentwood Bob
Default Re: Starter stuck
Starter bendix stuck.
Several causes I can think of:
1. Broken bendix Spring
2. Bent starter shaft
3. Not allowing the engine to quit turning over between applications of the starter.
4. Bolt came out of starter spring.
5. Broken bendix.
Brentwood Bob is offline   Reply With Quote
Old 03-22-2021, 09:01 PM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Sounds like a bad switch.
Ivan in southeast va. is offline   Reply With Quote
Old 03-22-2021, 09:10 PM   #4
JayJay
There is very little on any stuck starter than cannot be cured, or at least improved, by a proper whack with a hammer.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 03-22-2021, 09:36 PM   #5
Brentwood Bob
Keep the hammer handy. Or watch this series on rebuilding the starter switch.
https://m.youtube.com/watch?v=lDBNoU0ZvLQ
Old 03-22-2021, 10:08 PM   #6
CWPASADENA
CWPASADENA's Avatar
X2,
There is nothing inside the starter to cause it to keep running. The switch is the only thing that will do that. It is either the switch itself or something is causing the rod to hang up when it is pushed and not allowing the spring inside the switch to return it to the up (off) position.
This is all assuming that you have an original starter and switch and not a aftermarket starter or a modified system where you are using an external remote solenoid.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-23-2021, 05:24 AM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Take the switch off and take it apart. Nothing to it. Fix it, or replace it.
Jacksonlll is offline   Reply With Quote
Old 03-23-2021, 07:27 AM   #8
johnbuckley
johnbuckley's Avatar
Isn't there a mention on fordbarn somewhere about a trick of putting a supplemental spring under the button on the starter pedal to ensure the rod is pulled up?
johnbuckley is offline   Reply With Quote
Old 03-23-2021, 08:10 AM   #9
Lefthander1930
Replacing the switch seems to be the best idea. Thanks for all the input.
Lefthander1930
Old 03-23-2021, 06:36 PM   #10
CWPASADENA
CWPASADENA's Avatar
Try to find a good original or a replacement made in the "old days".
A lot of the currently available electrical replacement parts are made "off shore" and are very poor quality.
Chris W.
Old 03-23-2021, 07:46 PM   #11
nkaminar
nkaminar's Avatar
A little electrical contact grease on the contacts will keep them from sticking, keep the oxidation down, and improve the conductivity. It can be used on any contacts, electrical connections, or connectors.
Old 03-23-2021, 07:49 PM   #12
Dirtrack49
Dirtrack49's Avatar
Most likely you don't need a new switch. Simply take it apart and clean up the copper contact with some sandpaper or a fine file.
The switch will weld itself together sometimes. Happened to me the first month I had my A. Kind of unnerving to say the least.
Tom L.
Dirtrack49 is offline   Reply With Quote
Old 03-24-2021, 12:26 PM   #13
jg61hawk
Funny it happened to Dirtrack "first month"... same to me like within the first month. I had the old crank handle under the seat and smacked it. Stopped it. Happened twice more in a week, new switch on top of starter and that was that 7 seven years ago.
jg61hawk is offline   Reply With Quote
