Old 04-22-2020, 01:30 PM   #1
john charlton
john charlton's Avatar
Default Rear Motor Mount Bolts
Just sorting out some bolts to install the rear motor mount to the flywheel housing . I have some that would do but are cross drilled for a lock wire and some plain.
Originally were they lock wired or with a lock washer . Just curious .
John in lovely locked down Spring Weather Suffolk County England .
john charlton is offline   Reply With Quote
Old 04-22-2020, 01:50 PM   #2
jb-ob
Default Re: Rear Motor Mount Bolts
Originals where drilled to accept cotter (split ) pins.
Quite nice here too in Nassau County, along side Suffolk County, USA
jb
jb-ob is offline   Reply With Quote
Old 04-22-2020, 02:05 PM   #3
31Cabriolet68-C
31Cabriolet68-C's Avatar
Per RG/JS, Sec 1-9,
"The heads of the bolts were safety wired in various ways with 18 gauge plain or raven finished wire."
No mention of lock washers....
TallyHo
31Cabriolet68-C is offline   Reply With Quote
Old 04-22-2020, 02:08 PM   #4
31Cabriolet68-C
Ooops, Should have typed:
Section 1-5 Revised 2011
Old 04-22-2020, 02:23 PM   #5
Gary Karr
Gary Karr's Avatar
The rear engine mounts were bolted to flywheel housing with unfinished bolts AND lock washers and wired with 18 gauge wire which was plain or raven.
Gary Karr is offline   Reply With Quote
Old 04-22-2020, 02:28 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
jb
Originally Posted by 31Cabriolet68-C View Post
Per RG/JS, Sec 1-9,
Research the following;
A-21207 Bolt - housing to rear engine support.
A-22330 Lock Washer
A-6402 Wire - engine support to flywheel housing support wire
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-22-2020, 05:36 PM   #7
jb-ob
The above are correct......why did I read but think of the smaller motor mount to frame bolts???
Week 6 'Interment Camp Cuomo'.........
Old 04-23-2020, 03:41 AM   #8
john charlton
Thank you all very much all is crystal clear . All my cars have lock washers and oddly enough not had any with wire . None are original so many motor changes over the years .
John in yet another glorious Spring Day we are heading for the warmest April on record and no Model A !!! Suffolk County England .
