Old 02-09-2020, 12:14 AM   #1
corsair_kid1979
corsair_kid1979's Avatar
Default Using later valves in a '39 flathead
Just wondering if you can use the later 8BA style valves and guides in the earlier flathead blocks? I have a bunch of valves, but not many guides. Seems the later valve and guides are cheaper than the split-style guides.
corsair_kid1979 is offline   Reply With Quote
Old 02-09-2020, 05:22 AM   #2
marko39
Default Re: Using later valves in a '39 flathead
This should pose no problem as long as the complete 8ba assembly is used. I opened up a 38 engine for inspection and it had one 8ba valve and the rest mushrooms.
marko39 is offline   Reply With Quote
Old 02-09-2020, 06:54 AM   #3
Mac VP
Mac VP's Avatar
You can definitely use the later (8BA type) valves in your 39 block.....just use the matching 8BA valve components with them (springs, spring retainers, keepers, guides). The valve guide retainers (40-6510) are the same either way.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 02-09-2020, 08:46 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
This is pretty much what all of us do . . . as the split guides tend to move around a bit (between the two) and are harder on valve stems as a result. The best situation is to buy a whole valve assembly "kit" - where you have the valves, guides, retainers, keepers and springs. Mac is a good supplier for these parts - as are others.
Old 02-09-2020, 11:14 AM   #5
JSeery
JSeery's Avatar
B&S, Corsair is a new poster here on the Barn, I thought we might want to be sure he understands your reference to Mac is Mac VanPlet, NOT Mac's!
http://www.vanpeltsales.com/
Lots of good information on his site in addition to the parts for sell.
Old 02-09-2020, 03:28 PM   #6
corsair_kid1979
Thanks guys for this. I am relatively new here, but somewhat of a regular on the HAMB forum. Thanks for the info, rather new to the flathead, but have worked on a few over the years.
Old 02-10-2020, 01:05 PM   #7
supereal
supereal's Avatar
We use Chevy valves when we rebuild flatheads. They are less costly, and easier to find.
supereal is offline   Reply With Quote
