08-14-2019, 08:49 AM | #1 |
radiator for 55 merc with 302
Gentlemen I have a brand new radiator for my 53 but when I tried it in the 55 mercury the fan is too close any suggestions seems like I looking at the wrong places for radiators
08-14-2019, 12:08 PM | #2 |
Re: radiator for 55 merc with 302
Does vendor cataloging call for the 53 to fit a 55?
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
08-14-2019, 02:43 PM | #3 |
Probably because the '53 was a flathead V8 and the '55 is a 292 Y-Block OHV V8. Plus the '53 radiator will have two upper hoses and two lower hoses. '55 used one on top and one on the bottom. Can't see the '53 radiator working in a '55 at all.
Sal |
08-16-2019, 11:32 AM | #4 |
what radiator would I use for 302 in 55 mercury montclair
08-16-2019, 01:03 PM | #5 |
Does it fit well in the '55 Merc original radiator support?
Is the spacer between the pulley and fan too long? . Last edited by dmsfrr; 08-17-2019 at 10:36 AM. Reason: reading comprehension failure |
08-17-2019, 05:44 AM | #6 |
08-17-2019, 06:22 AM | #7 | |
No one sure answer.
08-17-2019, 05:38 PM | #8 |
it came out of a 1978 ford Granada with automatic tranny ,but it has been changed over to three on the floor
08-17-2019, 08:31 PM | #9 |
What you might want to do is call CHAMPION - https://www.championradiators.com/ - and get an idea. They will want some measurements I suppose and you have retained the original 55 MERC core support, correct?
08-18-2019, 07:21 PM | #10 |
Yes I have retained original core support
08-19-2019, 04:31 AM | #11 |
You can shorten up the 302 by about 3 1/2" by using the 1966-69 289 "short" water pump and harmonic balancer. Here is what is involved in detail. ( Read Post #5) https://www.jalopyjournal.com/forum/...ulleys.303600/ In 1952-56 Fords the 6 cylinder cars had the radiator further forward because of a difference in the lower sheet metal panels, since Mercury did not use the Six you have to get creative to move it forward which involves cutting the splash panel.
