Old 10-27-2018, 04:16 PM   #1
LeRoiGross
Default Door Hinges
I am having trouble fitting the front doors of my 1929 Phaeton and I think it may be the lower hinges. In the attached picture you can see the Hinge leaves on one lower hinge are 6/32 apart and on the other are 3/16 apart. Note the difference in the bend at the pin. What is the correct spacing? Can I bend the right one with my 12 ton press with out damaging it?
LeRoiGross is offline   Reply With Quote
Old 11-01-2018, 04:24 PM   #2
LeRoiGross
Default Re: Door Hinges
Just discovered I made a typo in my posting. The 6/32 should be 3/32. So I have one hinge with a 3/32 gap and the other with a 3/16 gap.
Old 11-01-2018, 04:49 PM   #3
Oldbluoval
Oldbluoval's Avatar
Any chance one of them is assembled "backward"?
That is the knuckles are reversed
I could be entirely off base but only seeing one pic
Oldbluoval is offline   Reply With Quote
Old 11-01-2018, 04:50 PM   #4
fundytides
fundytides's Avatar
Are these new hinges? If they are used, someone probably bent one to compensate for door sag. This was commonly done on older cars. To me, the bottom hinge in the picture looks most correct. Your best bet is to see if you can get a look at a set of hinges on someone's 28-30 Phaeton or Roadster which should have the same front door hinges. Failing that, contact your favorite parts supplier and se if you can get a picture or description of a new hinge.
fundytides is offline   Reply With Quote
