Old 04-19-2021, 02:09 PM   #21
1931 flamingo
1931 flamingo's Avatar
Default Re: 1949 Ford Starter
Be wary of a new starter. I got one about a year ago and the armature was out of round ! ! by a lot.
Paul in CT
Old 04-19-2021, 04:59 PM   #22
Rayfry
Well I did it. Got the new starter in and busted my butt. Laying under the car on a creeper trying to install a 20 lb starter. The new starter with that Bendix drive is a challenge to line up. Going to get the original starter rebuilt and probably put it on eBay. Thanks for all your help.
Rayfry is offline   Reply With Quote
Old 04-19-2021, 06:44 PM   #23
JSeery
JSeery's Avatar
A good way to go is to convert it 12v. There is a lot of information here on the Barn on which 12v starters are good donors for the case.
Old 04-19-2021, 07:25 PM   #24
Rayfry
I did convert to 12 volt. I removed the 6 volt starter and installed a 12 volt.
Old 04-19-2021, 08:22 PM   #25
JSeery
JSeery's Avatar
LOL, not the same thing. I was referring to covering your original 6v starter to a 12v starter. You can get a later Ford 12v starter out of the late 50s and 60 and merge the pieces together with your existing 6v one and end up with a nice setup. If you are interested in that approach I'll look up some post/articles on it.
Old 04-20-2021, 06:24 AM   #26
Rayfry
Sorry I miss understood what you meant. Its in and working for now so I'm happy to be back on the road. Next project is a leaking transmission.
Old 04-20-2021, 07:55 AM   #27
JSeery
JSeery's Avatar
Rayfry, keep us updated on how well your stater performs. It's possible it will work great for years!
Old 05-03-2021, 06:19 PM   #28
Rayfry
So far the new starter is working fine . Starts everytime.
