Old 01-21-2021, 08:06 PM   #1
tinman7
tinman7's Avatar
Default Directionals
Having trouble with my blinkers
. Installed new unit on the steering wheel and it works well when the car is not running have leds on the front bumpers and less in the rear tail lites and a led bar in the back window. Any Ideas why they won't blink when I run the car, they light and I can manually make them work but the flasher won't go?
tinman7 is offline   Reply With Quote
Old 01-21-2021, 08:48 PM   #2
dbaldwi3
dbaldwi3's Avatar
Default Re: Directionals
Do you have the correct flasher? You must use an led flasher for the proper operation.
dbaldwi3 is offline   Reply With Quote
Old 01-21-2021, 08:58 PM   #3
Ordsgt
Ordsgt's Avatar
some LED lights have a resister built into them so a regular flasher will work, that is the type in my A. If you have a combination of LED without resister and regular flasher it will not work. When your car is not running will the flashers work?
Ordsgt is offline   Reply With Quote
Old 01-22-2021, 05:26 AM   #4
shew01
shew01's Avatar
I had the same problem because I was using a thermal flasher. LED lights draw less current; so, there is not enough draw to trigger a thermal flasher. I tried some LED flashers, which worked great when the engine was off, but they went nuts with the engine running (because of the static generated by the engine).
This is what worked the best for me. My Signal Stat 900 pilot light does not work, but the signals blink fine with the motor running and with it stopped.
https://www.ebay.com/itm/NOS-IDEAL-6....m46890.l49292
Or, you can try adding load resistors to the circuit.
Old 01-22-2021, 07:35 AM   #5
Patrick L.
Patrick L.'s Avatar
There is a lot of info in the archives/search.
Plus more info is needed such as voltage and ground.
Old 01-22-2021, 09:12 AM   #6
eagle
eagle's Avatar
If they work fine with the engine off, then its likely an issue with the noisy electrical system on the Model A. Get a dc noise filter from ebay or amazon and put it ahead of the flasher. Make sure it has a good clean ground or it won't do much good. Browning makes a pretty decent one
Old 01-22-2021, 12:41 PM   #7
CarlG
CarlG's Avatar
My set up: Signal Stat 900, 12-Volt Neg ground, all LED fixtures.
After trying all the usual flashers, including "electronic" ones, none worked satisfactorily due to all the reasons already discussed.
This flasher, however, works perfectly.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-22-2021, 12:57 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Carl, I have that same flasher. When it works it works good. However I have had two burn out in the last 2-3 years, this last one has ~6months on it so far...
Old 01-22-2021, 01:02 PM   #9
Jerry in Shasta
Jerry in Shasta's Avatar
Make sure the switch on the steering column is well grounded.
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 01-22-2021, 09:32 PM   #10
tinman7
tinman7's Avatar
Got it working! Needed two Resistors and a non electronic flasher. This was a 12 volt led system.
Old 01-23-2021, 07:33 AM   #11
shew01
shew01's Avatar
Good for you! I love that “rush” when something finally works. :-)
Old 01-24-2021, 12:02 AM   #12
Stew
Stew's Avatar
Try this flasher. It is made for LED's
https://www.ebay.com/itm/3-Pin-Prong...UAAOSwPMle5m4K
Stew is offline   Reply With Quote
Old 01-24-2021, 01:03 AM   #13
CarlG
CarlG's Avatar
When I tried that one, it worked perfectly -- until I started the engine. It would not work at all with the engine running, Worked OK with the engine off.
Alaskan A's
Old 01-24-2021, 07:52 AM   #14
shew01
shew01's Avatar
I had the same experience with it.
Old 01-25-2021, 12:43 AM   #15
GeneBob
I fought the LED bulbs vs turn signal flasher for awhile. I finally added a brake light socket tied to my steering column with the left turn signal going through one of the bulb filaments and the right turn signal going through the other. The separate bulb contacts and filaments prevent cross talk in the turn signals. This added sufficient resistance to the circuit for the thermal flasher to function and lights up under the dash so I will not forget to cancel my turn signals. Kinda silly, but it worked.
GeneBob is offline   Reply With Quote
Old 01-25-2021, 05:25 AM   #16
shew01
shew01's Avatar
That’s similar to the way the my car’s previous owner wired my car. He used a plain bulb in place of the dash light, and he had two wires (one for each tail light circuit) connected so that the dash light would flash every time the signal toggle was turned on. It worked great in the day, but it was annoying during the night (because of the placement of the bulb).
Old 01-28-2021, 01:07 PM   #17
Dan McEachern
What value resistor and how did you wire it in with the tail light bulb?
Dan McEachern is offline   Reply With Quote
