01-05-2021, 08:14 PM | #1 |
C69a
Information om a c 69 a engine
01-05-2021, 08:17 PM | #2 |
Re: C69a
What?????
01-05-2021, 08:21 PM | #3 |
Re: C69a
That's a Canadian pre-ww2 flathead 24 stud, probably has the military extra oil pressure port on the bell housing. Similar to the US 59A ,but always there are the Military bearing surprises. Newc
01-05-2021, 08:37 PM | #4 |
Re: C69a
Also, see my post on the boring of one
Lawrie |
01-05-2021, 11:46 PM | #5 |
Re: C69a
Information; they have real thick cylinder walls.
They displace 239 cu inches, run a two hole per journal crank, with shell bearing con rods. These are NOT the same as 8BA version. Those shell bearings are impossible to find nowadays, however, regular 239 floaters can be substituted. Originally, the valve rotator valve setup was fitted, and only exhaust valves had hardened seats.
01-06-2021, 06:40 PM | #6 |
Re: C69a
