09-01-2020, 08:31 PM | #1 |
Windshield Frame
I am installing a new windshield frame on my 1929 Phaeton and I need to drill the holes for the roof snaps. Does anyone have the layout dimensions for the 6 holes? How many inches from the left corner and then all the way across. I can't install my new roof until I get the snaps installed. Any problems in using the snaps with 10-32 screws in them?
11-06-2020, 01:05 PM | #2 |
Re: Windshield Frame
Same here. The existing frame is not correct (oval and chromed). It has snaps, but I want to make sure the new frame is correctly done. The new roof will come after.
Any help with measurements?? |
11-06-2020, 03:44 PM | #3 | ||
I guess I missed reading the first post asking for this. While I have the dimensions taken from the print, it should be noted that most top kit manufacturers want those dimensions before they sew a top. If you already have a top, then you will want to use your existing flap snaps to locate the snaps for the windshield frame. I have included a PDF that shows the correct location. . |
11-06-2020, 09:38 PM | #4 |
Repeated reply.
11-07-2020, 08:18 AM | #5 | |
My top is shot and the windshield is not right, so I've got a new blank steel frame. Your measurements are a great help. Question: This shows a hole for the wiper. I have posted a query about the authenticity of the Trico vacuum wiper that came on my '29 Phaeton - it was clipped the frame with no holes. Would an authentic mounting of the wiper been with clips and one hole for the wiper? Best, Tom |
