10-27-2018, 04:16 PM | #1 |
Door Hinges
I am having trouble fitting the front doors of my 1929 Phaeton and I think it may be the lower hinges. In the attached picture you can see the Hinge leaves on one lower hinge are 6/32 apart and on the other are 3/16 apart. Note the difference in the bend at the pin. What is the correct spacing? Can I bend the right one with my 12 ton press with out damaging it?
11-01-2018, 04:24 PM | #2 |
Re: Door Hinges
Just discovered I made a typo in my posting. The 6/32 should be 3/32. So I have one hinge with a 3/32 gap and the other with a 3/16 gap.
11-01-2018, 04:49 PM | #3 |
Re: Door Hinges
Any chance one of them is assembled "backward"?
That is the knuckles are reversed I could be entirely off base but only seeing one pic |
11-01-2018, 04:50 PM | #4 |
Re: Door Hinges
