Old 04-11-2015, 08:36 PM   #1
johndee138
johndee138's Avatar
Default slow starter when warm
OK fellas, Ive read most of the posts re: slow starters, so here is my question.
I have no problem with initial starter cranking when the car is cool and it will crank and run nicely. After a ride around for a bit, stop and come back to ride away, it always cranks, but never like it does when cool. I put a insulation wrap around the body of the starter thinking it may be getting too warm next to the exhaust manifold. Initial crank up leads me to believe that connections are satisfactory for electrical flow. What should I look at next to diagnose the problem?
Thanks ALL!!
johndee138 is offline   Reply With Quote
Old 04-11-2015, 09:23 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: slow starter when warm
JD
That is when poor connections show up, with a bigger load.
You read the posts so you know the drill.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 04-11-2015, 09:30 PM   #3
tubman
tubman's Avatar
I had the same problem with my '51. Checked and cleaned grounds and connections to no avail. Then I realized I had a group 1 battery in it (I needed a new battery the year before in a pinch, and it was all that was available). Group 1 batteries are quite a bit smaller than what originally came in Fords and are used in tractors, etc. I replaced it with an Optima and all the problems disappeared. The proper battery that's not 100% could have the same problem.
Old 04-12-2015, 07:06 AM   #4
Talkwrench
Talkwrench's Avatar
If it feels like a flat battery, chances are it's poling , soon it will fail.
Old 04-12-2015, 09:21 AM   #5
nobey
nobey's Avatar
Try cleaning or turning the armature, installing new brushes and springs.
Also make sure the starter has a good clean ground against the pan "no paint".
With a good battery, and connections your hot start problem should go away.
nobey is offline   Reply With Quote
Old 04-12-2015, 07:22 PM   #6
Tom Mazz/CT
Tom Mazz/CT's Avatar
JD,
I had a similar problem with my V8 cranking slow when hot - search my previous thread "Will a starter heatshield help"
Tom
Tom Mazz/CT is offline   Reply With Quote
Old 04-13-2015, 01:07 PM   #7
1931 flamingo
1931 flamingo's Avatar
Tom: Nice avatar ! Brings back memories.
Paul
Old 04-13-2015, 06:56 PM   #8
russcc
You may want to have the battery load tested.
Old 04-15-2015, 08:25 AM   #9
325w
Cable size makes a difference also. Positive and ground.
325w is offline   Reply With Quote
Old 04-15-2015, 11:35 AM   #10
adileo
adileo's Avatar
Has anyone found that poor air filters may cause problems with warm start?
adileo is offline   Reply With Quote
