07-05-2021, 05:41 AM | #1 |
Stupid paint question...
Can primer be clearcoated?
07-05-2021, 06:19 AM | #2 |
Re: Stupid paint question...
Stupid answer red, grey or black?
Cheers, Jim&Sandy McGregor, IA |
07-05-2021, 09:28 AM | #3 |
Google is your friend.
https://www.google.com/search?q=can+...hrome&ie=UTF-8 |
07-05-2021, 11:13 AM | #4 |
07-05-2021, 12:06 PM | #5 |
As long as it is the same basic product. Catalyzed Urethane clear over catalyzed urethane primer, color irrelevant. I personally wouldn't use lacquer primer on a garbage can.
07-05-2021, 03:58 PM | #6 | |
Painted garbage cans? I am not worthy....
07-05-2021, 09:41 PM | #7 |
Just make sure you use FLAT clearcoat. If you add any gloss it just looks like paint (paint that peels). But primer by itself looks great, I have never seen a reason to candy coat it. If someday the primer starts to wear off, spray a little more over the top, and get back in and go for a drive. It dries best at 50 mph plus.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
07-05-2021, 09:43 PM | #8 | |
07-06-2021, 10:57 AM | #9 |
07-06-2021, 11:01 AM | #10 |
I think someone makes a semi-flat or satin top coat for this very application. I would search the HAMB for I recall a few threads about this.
07-06-2021, 12:47 PM | #11 |
Okay, you got me laughing A LOT. Thanks for the smiles
07-06-2021, 10:38 PM | #12 |
I think you can clear coat a turd. But why?
07-07-2021, 06:22 AM | #13 |
Well in that case I don’t know. ‘Corse I don’t know about red either nor black but at least I know what color primer your thinking of using.
07-07-2021, 12:16 PM | #14 |
Last year, I painted the frame and a bunch of parts, all in mix it up urethane, sprayed with a gun. I'm not really looking forward to doing that all over on a grander scale with the body. The body's from Brookville and it's still bare metal except I rattle canned the bottom and interior. The color of the bare metal is growing on me and just shooting a coat or two of grey primer and getting it on the road is attractive.
Don't never get rid of nuthin! Last edited by PeteVS; 07-07-2021 at 12:28 PM. |
07-07-2021, 12:43 PM | #15 | |
Not sure the cost involved but what about ceramic clear coat? Would last longer than a wax and would prevent corrosion with a durable finish. I think it's just applied with a sponge. I've seen guys use this ceramic coating for rims with good results.
Sometimes, ingenuity gets in the way of sense and sanity. Last edited by Will D; 07-07-2021 at 12:45 PM. Reason: Typo |
07-07-2021, 01:38 PM | #16 | |
