Old 05-27-2021, 04:09 PM   #1
rayro39
rayro39's Avatar
Default 1939 Ford sedan horn/light switch..?
Is the horn button also serve as light switch, or are those the blinkers..?
Also, at the very base of the steering column next to motor, is that the light switch..?
There is one toggle switch under dash that turns on dash gauge light, but nothing else.
Complete 39 Ford Newbie. Any help appreciated!
rayro39 is offline   Reply With Quote
Old 05-27-2021, 04:19 PM   #2
1939mars
1939mars's Avatar
Default Re: 1939 Ford sedan horn/light switch..?
Yes the horn button is the center and the part that you can rotate just outside of the button is the light switch, not blinkers. Did not originally come with blinkers though yours may have them. Rotate clockwise should be parking lights and CCW headlights.
Yes the bulb at the base of the steering column is the guts of the light switch and horn. The steering boxes are notorious for leaking grease down into that bulb so be sure to keep it clean for the brightest lights.
Yes there is just the one switch for the dash lights. There should be a foot switch on the left for high/low beams. There may also be a dome light switch somewhere - I have a pickup so don't have that and can't say for sure. Are you looking for something else?
1939mars is offline   Reply With Quote
Old 05-27-2021, 04:48 PM   #3
JSeery
JSeery's Avatar
Here are the wire routing diagram and the 39 std wiring.
File Type: jpg Flathead_Electrical_wirediagram1938-39car.jpg (78.0 KB, 28 views)
Old 05-27-2021, 04:57 PM   #4
rayro39
rayro39's Avatar
1939Mars: "The steering boxes are notorious for leaking grease down into that bulb"
Yes it is. It's caked with oil right now.
Thank you guys for the info and diagrams!
Old 05-27-2021, 05:42 PM   #5
ford38v8
ford38v8's Avatar
They are usually caked with oil/dirt on the outside. The inside should remain clean.
Alan
Old 05-27-2021, 08:16 PM   #6
GaryU.
GaryU.'s Avatar
Also since these are your first posts, Welcome Aboard! You have come to the right place to get help and information. If you feel like it you can add your general location as there are many members that could offer assistance in person as well. Pictures of your beauty are also appreciated.
GaryU. is offline   Reply With Quote
Old 05-27-2021, 08:51 PM   #7
JSeery
JSeery's Avatar
Your avatar looks like you have a deluxe, so I'll add that wiring diagram
Old 05-27-2021, 10:57 PM   #8
rayro39
rayro39's Avatar
Thank you for the info!
Old 05-28-2021, 05:32 PM   #9
schwartzstuart6
Here to read comments and learn
Sent from my SM-A107F using Tapatalk
schwartzstuart6 is offline   Reply With Quote
Thread Tools
Display Modes
