Old 06-26-2020, 09:32 PM   #41
Will D
Will D's Avatar
Default Re: Drive shaft lock pin
Thank you for the kind words V8COOPMAN.
A few people have reached out and received a piece of heat shrink. I ended up with 4ft of the stuff as the 1ft was not available due to covid. I still have more left and the offer still stands for any who want a piece.
Will D is offline   Reply With Quote
Old 06-27-2020, 08:37 PM   #42
deuce_roadster
deuce_roadster's Avatar
Will D, Glad to spread the word on a solution to those pesky ends coming out if the pin breaks. I am pretty sure they will NEVER come through that sleeve. Good for you making the extra pieces available to someone who may have trouble finding it. I gave one to a Regional Group member who was assembling a rear end.
This is what this forum is for.
Old 07-26-2021, 05:23 PM   #43
Detonator
Detonator's Avatar
So...how many days' pounding does it take to peen over an original pin? I got a couple of OEM pins from Fred Willner (Southside Obsolete) and a couple of aftermarket ones from C&G. I decided to go with the originals -- and I think that was a mistake. After 5 or ten minutes of pounding (it's well backed-up) this is all I've gotten. Are the new pins a lot softer?
If I switch to the C&G pins, how much stick out should I leave when I trim 'em down? Thanks.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 07-26-2021, 06:12 PM   #44
deuce_roadster
If that end sticking out was heated dull cherry red (with the red and green wrench), it would have been peened over in short order. Something that small would have heated up really fast and not overheated anything else.
Old 07-26-2021, 06:46 PM   #45
Will D
Will D's Avatar
Does your C&G pins have a hollow tip? The ones I used did. I did not trim at all, just a few wacks with the hammer(see post #39). If using NOS, do as deuce_roadster suggested.
Sometimes, ingenuity gets in the way of sense and sanity.
Old 07-26-2021, 09:19 PM   #46
Tinker
Tinker's Avatar
It's just a pin that holds a collar in place. If the splines are tight there is no reason other then decades of spline wear for a pin to break under normal flathead power. Removed a couple with the pin at the bottom, it still worked and ran before I even knew it. I'd guess having more parts flopping around would be fine. Heat shield makes sense. Probably hold up for quite a while at least keep the pin from dropping if it shears.
Old 07-26-2021, 10:05 PM   #47
Detonator
Detonator's Avatar
The pinion is new — just put in 3.54s — and the coupler’s NOS so there’s no play at all. I think I’ll grind this one off and drive it back out, and use the softer C&G. Then shrink wrap it. I like that.
Seabright Hot Rods
Old 07-27-2021, 06:53 AM   #48
glennpm
glennpm's Avatar
I want to warn folks against using the"safety lock pin" device. After just a few hundred miles I found this damage. Needless to say, I didn't put it back in. I used one of the hollow end pins, swagged it over and then used a piece of shrink tubing that I got from Will D (thank you!)
Old 07-27-2021, 09:19 AM   #49
Mart
Mart's Avatar
^^ The images above are not indicating a problem with the pin. They are indicating that you have too much play between the splined coupler and the pinion. It is that play that works the pin and eventually fatigues it to failure. If it was not the safety type, it would eventually break and the parts will fall out and make a noise. If that one broke, the clip will retain the parts in place.
Good tight fitting splines, and perfect alignment are crucial. Any slop or as can happen with shortened drivelines, misalignment will lead to spline wear and failed pins.
Mart.
Old 07-27-2021, 09:25 AM   #50
glennpm
glennpm's Avatar
Agreed Mart
Old 07-27-2021, 01:48 PM   #51
19Fordy
19Fordy's Avatar
This is one of the best threads ever. Thanks for the industrial heat shrink info.
Old 07-27-2021, 05:56 PM   #52
Detonator
Detonator's Avatar
Just a follow up: I cut the C&G pins to length and the peened over readily.
Seabright Hot Rods
Old 05-17-2023, 07:18 PM   #53
bill h
If both of the pins are broken will the car still drive.. What kind of noise or vibration would you get with broken pins
bill h is offline   Reply With Quote
Old 05-17-2023, 07:49 PM   #54
blownford
No buggering up! Ha!
blownford is offline   Reply With Quote
Old 05-17-2023, 07:53 PM   #55
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
