Old 07-25-2021, 12:55 PM   #1
Andy
Default Center bearing
I built a 40 rear end for my 32. The torque tube was cut for the flange. I cut it again near the center bearig just to see it. It is different than ones offered by the parts venders. It appears to be a caged roller bearing and the replacements look like ball bearings. Anybody want it? I would send it for postage. I hate to see any of the old parts scraped if I can help it.
I have no way of checking it for wear. If anyone has the dia of the driveshaft, I would machine a part to check fit.
Andy is online now   Reply With Quote
Old 07-25-2021, 02:31 PM   #2
Shoovel
Shoovel's Avatar
Default Re: Center bearing
Andy,
Check out VanPelts website, they have a pretty good pic of the torque tube.
Shoovel is offline   Reply With Quote
Old 07-25-2021, 02:55 PM   #3
19Fordy
19Fordy's Avatar
Andy: The OEM 40 center bearing is a special caged roller bearing encased in rubber with a hole for greasing. Over time the rubber will desintigrate, turning to mush. The original 40 OEM center bearing looks like the last photo. The driveshaft is not a tight fit in the bearing and easily slides in and out. Posting a photo of what you have would be helpful. Thanks for making your part available.
Old 07-25-2021, 05:01 PM   #4
Andy
I took some pictures but the server is giving me problems. I have to email the pics to myself and then transfer to photos. It is not sending the pics back.
It looks like the posted pic. The rubber is soft but I can't pull the bearing out. I doubt if it is usable but I have no experience with them. It is not mushy.
Old 07-25-2021, 06:12 PM   #5
19Fordy
19Fordy's Avatar
Wish we had some photos.
Old 07-25-2021, 09:14 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Andy .....Try e-mailing the pic to me and I'll try to post it. DD
[email protected]
Click Links Below __
T5 W/TORQUE TUBE
Old 07-25-2021, 09:54 PM   #7
Andy
Thanks Coop.
I finally got it to work. For what it's worth, here they are. I cut some of the bearing off as I did not know how wide it was.
Old 07-25-2021, 10:05 PM   #8
G.M.
[email protected] makes a replacement. G.M.
www.fordcollector.com
Old 07-25-2021, 10:10 PM   #9
deuce_roadster
deuce_roadster's Avatar
Usually the rubber that holds the bearing has turned to snot. i have a picture of a NOS bearing in the Std Coupe album and the KRW tool that installs it in my MISC photo album.
Old 07-26-2021, 12:28 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Mike's NOS Center Bearing & KR Wilson Installation Tool. You guys are in for a treat if you go to Mike's ALBUMS. He has some really cool stuff, and does some beautiful restoration work on his own cars. DD
T5 W/TORQUE TUBE
Old 07-26-2021, 04:49 PM   #11
19Fordy
19Fordy's Avatar
Andy, That bearing rubber casing is too far gone. No longer usable.
Thanks for posting the pix.
I keep thinking there must be a way to re-encase the metal part of the OEM bearing
in a suitable material that will allow it to be reused. Perhaps the material that skate board wheels are made of or DELRIN.
Here's a thread that provides center bearing dimensions.
https://www.fordbarn.com/forum/showt...r+bearing+size
Old 07-26-2021, 06:35 PM   #12
deuce_roadster
19Fordy,
With some work making the drawing, maybe it could be made with 3D printing. Just a thought. And thanks for your kind words Dick!
Old 07-26-2021, 06:55 PM   #13
Will D
Will D's Avatar
Here's instructions on replacing the rubber if anyone is up for the challenge.
Page 17, about halfway down the thread.
https://www.jalopyjournal.com/forum/...981440/page-17
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 07-27-2021, 02:19 PM   #14
Andy
More confusion from me.
Since the consensus was that it was toast, I desided to investigate further. I cut the tube a couple of inches further away and tried to remove the bearing/rubber. Found an appropriate driver and wacked the bearing with my 8 lb sledge. I did seperate the inner tube from the torque tube. Nothing would dislodge the rubber from the inner tube or the bearing from the rubber. I had at it for quite a while. I finally dented the bearing cage and thru the mess away.
I am glad 32's don't use center brngs. I failed.
Old 07-27-2021, 02:56 PM   #15
19Fordy
19Fordy's Avatar
Andy, Thanks for perservering and sharing your center bearing ex[perience with us. Jim
Old 07-27-2021, 02:58 PM   #16
19Fordy
19Fordy's Avatar
Will D. Thanks for posting that info. on how Mike repaired his center bearing. I wish I had seen it before I paid huge $$$ for a new OEM bearing in 2017. I still have the saved metal bearing. JIM
Old 07-27-2021, 06:07 PM   #17
G.M.
Here is the instructions from Skips replacement center bearing. G.M.
Old 07-27-2021, 06:23 PM   #18
V8COOPMAN
V8COOPMAN's Avatar
This should be a little better! DD
T5 W/TORQUE TUBE
Old 07-27-2021, 08:35 PM   #19
Zeke3
Zeke3's Avatar
Much more better to read, my neck was getting sore.
Zeke3 is offline   Reply With Quote
