07-25-2021, 12:55 PM | #1 |
Center bearing
I built a 40 rear end for my 32. The torque tube was cut for the flange. I cut it again near the center bearig just to see it. It is different than ones offered by the parts venders. It appears to be a caged roller bearing and the replacements look like ball bearings. Anybody want it? I would send it for postage. I hate to see any of the old parts scraped if I can help it.
I have no way of checking it for wear. If anyone has the dia of the driveshaft, I would machine a part to check fit. |
07-25-2021, 02:31 PM | #2 |
Re: Center bearing
Andy,
Check out VanPelts website, they have a pretty good pic of the torque tube. |
07-25-2021, 02:55 PM | #3 |
Re: Center bearing
Andy: The OEM 40 center bearing is a special caged roller bearing encased in rubber with a hole for greasing. Over time the rubber will desintigrate, turning to mush. The original 40 OEM center bearing looks like the last photo. The driveshaft is not a tight fit in the bearing and easily slides in and out. Posting a photo of what you have would be helpful. Thanks for making your part available.
07-25-2021, 05:01 PM | #4 |
Re: Center bearing
I took some pictures but the server is giving me problems. I have to email the pics to myself and then transfer to photos. It is not sending the pics back.
It looks like the posted pic. The rubber is soft but I can't pull the bearing out. I doubt if it is usable but I have no experience with them. It is not mushy. |
07-25-2021, 06:12 PM | #5 |
Re: Center bearing
Wish we had some photos.
07-25-2021, 09:14 PM | #6 | |
Re: Center bearing
Andy .....Try e-mailing the pic to me and I'll try to post it. DD [email protected] .. |
07-25-2021, 09:54 PM | #7 |
Re: Center bearing
Thanks Coop.
I finally got it to work. For what it's worth, here they are. I cut some of the bearing off as I did not know how wide it was. |
07-25-2021, 10:05 PM | #8 |
Re: Center bearing
[email protected] makes a replacement. G.M.
www.fordcollector.com |
07-25-2021, 10:10 PM | #9 |
Re: Center bearing
Usually the rubber that holds the bearing has turned to snot. i have a picture of a NOS bearing in the Std Coupe album and the KRW tool that installs it in my MISC photo album.
07-26-2021, 12:28 AM | #10 | |
Re: Center bearing
Mike's NOS Center Bearing & KR Wilson Installation Tool. You guys are in for a treat if you go to Mike's ALBUMS. He has some really cool stuff, and does some beautiful restoration work on his own cars. DD .. |
07-26-2021, 04:49 PM | #11 |
Re: Center bearing
Andy, That bearing rubber casing is too far gone. No longer usable.
Thanks for posting the pix. I keep thinking there must be a way to re-encase the metal part of the OEM bearing in a suitable material that will allow it to be reused. Perhaps the material that skate board wheels are made of or DELRIN. Here's a thread that provides center bearing dimensions. https://www.fordbarn.com/forum/showt...r+bearing+size Last edited by 19Fordy; 07-26-2021 at 05:02 PM. |
07-26-2021, 06:35 PM | #12 |
Re: Center bearing
19Fordy,
With some work making the drawing, maybe it could be made with 3D printing. Just a thought. And thanks for your kind words Dick! |
07-26-2021, 06:55 PM | #13 |
Re: Center bearing
Here's instructions on replacing the rubber if anyone is up for the challenge.
Page 17, about halfway down the thread. https://www.jalopyjournal.com/forum/...981440/page-17
Sometimes, ingenuity gets in the way of sense and sanity. |
07-27-2021, 02:19 PM | #14 |
Re: Center bearing
More confusion from me.
Since the consensus was that it was toast, I desided to investigate further. I cut the tube a couple of inches further away and tried to remove the bearing/rubber. Found an appropriate driver and wacked the bearing with my 8 lb sledge. I did seperate the inner tube from the torque tube. Nothing would dislodge the rubber from the inner tube or the bearing from the rubber. I had at it for quite a while. I finally dented the bearing cage and thru the mess away. I am glad 32's don't use center brngs. I failed. |
07-27-2021, 02:56 PM | #15 |
Re: Center bearing
Andy, Thanks for perservering and sharing your center bearing ex[perience with us. Jim
07-27-2021, 02:58 PM | #16 |
Re: Center bearing
Will D. Thanks for posting that info. on how Mike repaired his center bearing. I wish I had seen it before I paid huge $$$ for a new OEM bearing in 2017. I still have the saved metal bearing. JIM
07-27-2021, 06:07 PM | #17 |
Re: Center bearing
Here is the instructions from Skips replacement center bearing. G.M.
07-27-2021, 06:23 PM | #18 | |
Re: Center bearing
This should be a little better! DD |
07-27-2021, 08:35 PM | #19 |
Re: Center bearing
Much more better to read, my neck was getting sore.
