Old 07-22-2021, 10:59 AM   #1
Marmon4x4
Default 1938 fan shroud
Has anybody had any luck making a fan shroud for a delux 38 ?
Marmon4x4 is offline   Reply With Quote
Old 07-22-2021, 01:55 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1938 fan shroud
Vintage Air makes an ABS plastic one but the fit description reads 1937, 38, 39 standard. Now a 39 standard would be like a 38 Deluxe so I figured it might be worth a mention.
I have made a lot of fairings for the helicopters from fiberglass over the years. I use foam as a make up buck since it can be removed after forming. Fiberglass isn't my favorite material to work with but it can be made to work with minimal cost.
Old 07-22-2021, 01:55 PM   #3
rotorwrench
repeat error
Old 07-22-2021, 02:04 PM   #4
Will D
Will D's Avatar
I have yet to make one for my '38 deluxe but here are some pictures FlatheadTed shared with me of one he made for his('36 if I remember correctly).
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 07-22-2021, 02:55 PM   #5
FlatheadTed
FlatheadTed's Avatar
some more
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 07-22-2021, 06:00 PM   #6
Bill OH
I removed the fan and hood sides. No problems. Done it for years.
Bill OH is offline   Reply With Quote
Old 07-23-2021, 08:22 AM   #7
1931 flamingo
1931 flamingo's Avatar
Instead of adding a shroud, why not fix the overheating problem??
Paul in CT
Old 07-23-2021, 10:09 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
"r'wrench" .....When you do a mod like that on a guy's helicopter, do you have to submit some sort of "STC"-type of paperwork, or are the fairings you mention part of an existing "STC" ....maybe an STC that you own? Just curious! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-23-2021, 10:15 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
[QUOTE=Will D;2038528]I have yet to make one for my '38 deluxe but here are some pictures FlatheadTed shared with me of one he made for his('36 if I remember correctly).
Will .....My question is: Is that a '36 PICK-UP, rather than a '36 CAR? If so, like-year pick-ups have way more room because the radiator doesn't lean-back in a pick-up near as much as the CAR radiator. Dick D
T5 W/TORQUE TUBE
