Old 01-28-2013, 10:51 PM   #1
ThomasN
ThomasN's Avatar
Default Foromatic
What should I figure $$$ for getting my 53 auto trans rebuilt? Not even sure if it needs it but now would be the time to do it with the engine out?
Thanks
ThomasN is offline   Reply With Quote
Old 01-28-2013, 11:07 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Foromatic
ThomasN
My uncle was a Fordamatic tech. He has been dead 25 years.
Like powerglides, hard to find service and parts these days.
Bruce
Works good
Lasts lomg time
cmbrucew is offline   Reply With Quote
Old 01-28-2013, 11:15 PM   #3
ThomasN
ThomasN's Avatar
Originally Posted by cmbrucew View Post
ThomasN
Bruce
Works good
Lasts lomg time
Thanks, this is why I am asking now. I wonder what would be the best replacement?
Thanks
Old 01-29-2013, 12:42 AM   #4
paleot
I replaced mine with a c4, If I had it to do over I would use an aod for the over drive option! Mine is wound pretty tight at 60 mph.By the way it is in a 53 customline two door sedan stock 239 8ba.
Tony
paleot is offline   Reply With Quote
Old 01-29-2013, 01:24 AM   #5
ThomasN
ThomasN's Avatar
The one I am redoing is a 53 vic, stock 8ba. I have a 53 and a 54 donor car but just the 1 with automatic that I am using. How much trouble was the c4 to install/
Thanks
Old 01-29-2013, 10:46 AM   #6
TJ
TJ's Avatar
The C-4 is an easy install if you use the kit from Flat-O-Products in Oregon. I've installed two of them with flatheads. Speedway also makes a kit, but I have no experience with that one. I think the Speedway kit uses the larger torque converter. Use the stock Ford-o-Matic rear end or replace with a Maverick. You need a ratio in the rear around 3.25 to 3.45 for good power and cruising speed. You can also install the early Ford AOD.
Old 01-29-2013, 10:52 AM   #7
ThomasN
ThomasN's Avatar
Thanks TJ, very good advice here.
Old 01-29-2013, 12:16 PM   #8
36 flathead
If you use the fmx trans in the fordomatic case you get a true three speed. The last overhaul kit i bought was under 200. suppliers are listed in hemmings.
36 flathead is offline   Reply With Quote
Old 01-29-2013, 06:38 PM   #9
ThomasN
ThomasN's Avatar
Thanks, you guys are a wealth of informationm
Old 01-30-2013, 08:21 AM   #10
Wingfield
Wingfield's Avatar
I've got one I'll never use out next to my garage. Free, you pickup if interested.
Don't know the condition got it with a froze up motor.
Wingfield is offline   Reply With Quote
Old 01-30-2013, 10:01 AM   #11
ThomasN
ThomasN's Avatar
Thanks Wingfield, check PM
