Old 10-18-2021, 03:56 PM   #1
jstrez5
Default 1939 Ford Deluxe Center Piece
Hello All,
I recently bought a grill for my '39 ford deluxe. I'm having trouble fitting the center piece on and matching up the screws with the screw holes.
Just curious if anyone else has had an issue with this and what the solution was for it?
much appreciated!
jim
jstrez5 is offline   Reply With Quote
Old 10-18-2021, 04:56 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 1939 Ford Deluxe Center Piece
First question, is each grille bar separately made, then welded together to a perimeter frame that is also welded together? If so, that is likely an aftermarket grille (1940's to today's Argentina). Those grilles are notorious for poor fit.
Consider posting a photo of the grille (both front and back) and the trim (front and back). That will help us pick things apart.
Karl Wescott is offline   Reply With Quote
Old 10-18-2021, 06:31 PM   #3
jstrez5
Thanks, here are some pictures. Hopefully they go through.
jim
Old 10-22-2021, 05:24 AM   #4
swoopNZ
MEMBER EMERITUS
Looks ilke an aftermarket replacement grille - good luck.
swoopNZ is offline   Reply With Quote
Old 10-22-2021, 10:40 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Does indeed look like aftermarket.
In order to have parts fit together the holes will have to be elongated as required.
Old 10-23-2021, 10:06 AM   #6
jstrez5
Can anyone explain what characteristics qualifies it as an aftermarket?
I have two centerpieces (original one) fits perfect but it is pitted and not great to work with and the new Bob drake center piece doesn’t fit perfectly.
Jim
Old 10-31-2021, 04:23 PM   #7
billbrown
i hate it when this happens
billbrown is offline   Reply With Quote
