Old 10-01-2021, 07:20 PM   #1
Derek1937
Default Model a zenith carb problems
I have a Ford model a that I have bought 2 new zenith carbs that were supposed to be leak free and every time I run the car fuel leaks out the back of the carb. Any help on this would be awesome. Thanks
Derek1937 is offline   Reply With Quote
Old 10-01-2021, 07:39 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Model a zenith carb problems
See if this site is helpful: http://model-a.org/default.html
Old 10-01-2021, 08:25 PM   #3
Derek1937
Okay thanks I’ll check it out and see what I come up with!
Old 10-02-2021, 12:32 PM   #4
Gary WA
Gary WA's Avatar
http://www.model-a.org/
New style carbs or old rebuilt?http://www.model-a.org/
www.whidbeymodelaclub.com
Old 10-02-2021, 02:22 PM   #5
Derek1937
Originally Posted by Gary WA View Post
http://www.model-a.org/New style carbs or old rebuilt?http://www.model-a.org/
The ones I have bought were all old rebuilt ones
Old 10-03-2021, 11:01 AM   #6
Patrick L.
Patrick L.'s Avatar
When do they leak ? While running or when sitting ? Its usually just a needle/seat issue.
Old 10-04-2021, 07:34 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
You need to iterate the float level to stop the leak. Try using these tips:
Bob Bidonde
Old 10-04-2021, 08:22 AM   #8
700rpm
700rpm's Avatar
Great info Bob. Thanks for posting.
Ray Horton, Portland, OR
Old 10-04-2021, 11:14 AM   #9
Derek1937
Some times it leaks when it’s running but mostly when it sits it will start to leak a lot
