Old 09-22-2021, 09:05 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Tweaking Toe-In
Has anyone tried increasing the Model A's toe-in to improve tracking? Please, no comments about fixing the steering, caster or camber.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 09-22-2021, 10:22 AM   #2
GPierce
GPierce's Avatar
Default Re: Tweaking Toe-In
I discovered my toe-in was 7/16” when I noticed front tire wear was leaving a feathered edge, little ribs on one side of the tire next to the grooves. That’s a clear sign of excessive toe-in. I had no reason to suspect I had excessive toe-in prior to noticing the tire wear as the truck tracked and steered great.
I reset the toe-in to 1/16” and noticed no change in the steering or tracking.
A grossly exaggerated image of what the excessive toe-in caused.
File Type: jpeg 1545AE87-8216-4E8F-9945-4FA711DE46F5.jpeg (32.5 KB, 17 views)
GPierce is offline   Reply With Quote
Old 09-22-2021, 10:42 AM   #3
Dean Lemoine
Dean Lemoine's Avatar
I too noticed the front tires were both wearing a little on the outside, with 5000 miles on radial tires. I checked the toe in and found it was at 3/8 in. I set it a 1/16 with no noticeable change in the way it drives
Dean Lemoine is offline   Reply With Quote
Old 09-22-2021, 10:46 AM   #4
Patrick L.
Patrick L.'s Avatar
The toe was originally 1/4", but, with the roads getting better during that time Ford figured out that was too much and cut it back to 1/32- 1/16".
Old 09-22-2021, 02:35 PM   #5
Oldgearz
Problem I found with setting toe-in to 1/32 is that it is darn near impossible to do as a one person job. I need to find a shop here in North Idaho and see what they can do. Using the rod method, I get measurements at 2:00 o'clock and 7:30 o'clock instead of 3:00 and 9:00, and each measurement differs up to 1/8" or more. I've never been able to get the same measurement twice in a row. Set mine at about 1/8th inch and it tracks excellent. I have new tires so I probably won't see abnormal wear for 5,000 miles. At the rate I drive that will make me about 215 years old, and I'll be too stiff to get under the car to fix it.
Oldgearz is offline   Reply With Quote
Old 09-22-2021, 02:48 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
In later years (36)they came out with a specification that factored in camber, it is outlined in the 1936 service bulletins,
Old 09-22-2021, 03:03 PM   #7
nkaminar
nkaminar's Avatar
What ever happened to those old toe-n measuring machines that you drive over? They had moveable teeth that would move in or out as the car's front wheel drove over the machine. Such a simple mechanical device. No compfuers involved, no complicated setup, and quick and easy.
Old 09-22-2021, 04:33 PM   #8
Patrick L.
Patrick L.'s Avatar
Still have one, had to use it for the old state inspections. They were simple, not very accurate.
For cars such as ours I just use a tram bar or spring loaded gauge.
Old 09-22-2021, 04:38 PM   #9
Patrick L.
Patrick L.'s Avatar
I can understand that. Guess I'm used to it. Most of the time I just use a tram bar or spring gauge. I check it about three times, doesn't take too long.
