Old 09-27-2021, 10:51 PM   #1
steve hackel
steve hackel's Avatar
Default Threaded 'VS' welded steering arm balls
I have a pair of 32 spindles with out balls on them, and the holes at the end of the arms are tapered for a threaded ball - much the same as a typical,
but later tie rod end. Does anyone know where I can locate "threaded"
ball studs for these? I looked at Brattons and Snyders, but all they list
in their catalogs are the welded in studs. Thanks, Steve
steve hackel is offline   Reply With Quote
Old 09-27-2021, 10:56 PM   #2
updraught
updraught's Avatar
Default Re: Threaded 'VS' welded steering arm balls
Macs
updraught is offline   Reply With Quote
Old 09-28-2021, 10:52 AM   #3
Bob C
I got NOS ones from Fred at Southside Obsolete. http://www.southsideobsolete.com/Sou...e/Welcome.html
He goes by Barnfind08 on the early V8 forum.
I read that the taper on some of the new ones are not correct.
Old 09-28-2021, 02:58 PM   #4
Brian T
Brian T's Avatar
Hello Steve,
I was in the same boat until I found a pair of spindles that looked like new, searched-high low and found them at CW Ford, Orange County Ca. (800) 322-1932.
I just ordered a pair, dont forget to order the nuts if you dont have any.
Have a nice day Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 09-28-2021, 04:35 PM   #5
steve hackel
Thanks for all the suggestions, and I'll start calling them tomorrow. ��
Old 09-28-2021, 04:46 PM   #6
steve hackel
Heck, forgot all about California being 2 hours behind us back here - just ordered the parts I needed and they're on the way!
Thanks for the help.
Old 09-28-2021, 07:17 PM   #7
updraught
updraught's Avatar
The taper problem was fixed long ago I gather. The Macs ones are USA made and the correct iron oxide finish and hopefully hardened.
I've got 32 guts in my RHD two tooth.
