09-22-2021, 09:05 AM | #1 |
Tweaking Toe-In
Has anyone tried increasing the Model A's toe-in to improve tracking? Please, no comments about fixing the steering, caster or camber.
Bob Bidonde |
09-22-2021, 10:22 AM | #2 |
Re: Tweaking Toe-In
I discovered my toe-in was 7/16” when I noticed front tire wear was leaving a feathered edge, little ribs on one side of the tire next to the grooves. That’s a clear sign of excessive toe-in. I had no reason to suspect I had excessive toe-in prior to noticing the tire wear as the truck tracked and steered great.
I reset the toe-in to 1/16” and noticed no change in the steering or tracking. A grossly exaggerated image of what the excessive toe-in caused. Last edited by GPierce; 09-22-2021 at 10:37 AM. |
09-22-2021, 10:42 AM | #3 |
Re: Tweaking Toe-In
I too noticed the front tires were both wearing a little on the outside, with 5000 miles on radial tires. I checked the toe in and found it was at 3/8 in. I set it a 1/16 with no noticeable change in the way it drives
09-22-2021, 10:46 AM | #4 |
Re: Tweaking Toe-In
The toe was originally 1/4", but, with the roads getting better during that time Ford figured out that was too much and cut it back to 1/32- 1/16".
09-22-2021, 02:35 PM | #5 |
Re: Tweaking Toe-In
Problem I found with setting toe-in to 1/32 is that it is darn near impossible to do as a one person job. I need to find a shop here in North Idaho and see what they can do. Using the rod method, I get measurements at 2:00 o'clock and 7:30 o'clock instead of 3:00 and 9:00, and each measurement differs up to 1/8" or more. I've never been able to get the same measurement twice in a row. Set mine at about 1/8th inch and it tracks excellent. I have new tires so I probably won't see abnormal wear for 5,000 miles. At the rate I drive that will make me about 215 years old, and I'll be too stiff to get under the car to fix it.
09-22-2021, 02:48 PM | #6 |
Re: Tweaking Toe-In
09-22-2021, 03:03 PM | #7 |
Re: Tweaking Toe-In
What ever happened to those old toe-n measuring machines that you drive over? They had moveable teeth that would move in or out as the car's front wheel drove over the machine. Such a simple mechanical device. No compfuers involved, no complicated setup, and quick and easy.
09-22-2021, 04:33 PM | #8 | |
Re: Tweaking Toe-In
Still have one, had to use it for the old state inspections. They were simple, not very accurate. For cars such as ours I just use a tram bar or spring loaded gauge. |
09-22-2021, 04:38 PM | #9 | |
Re: Tweaking Toe-In
I can understand that. Guess I'm used to it. Most of the time I just use a tram bar or spring gauge. I check it about three times, doesn't take too long. |
