08-28-2021, 11:59 PM | #21 | |
Re: Any one have success with a repair??
08-29-2021, 12:04 AM | #22 |
If I couldn't find a replacement and it is indeed is made of pot metal, I would grind off a sixteenth or an eighth off the bottom and make a 1/16 or 1/8 steel "gasket" to replace what I ground off and glue it in place with JB Weld. Paint it and it will look original and will not break again.
As for the suggestion to 3D print one and cast it - this is doable but would involve a lot of work and skill. First you would need to make a CAD drawing, save it as an STL file and print it in PLA. Then you would cast it in aluminum using the "Lost PLA" method. Many hours of work compared to the 30 minutes or so involved in doing my suggested fix. |
08-29-2021, 08:13 AM | #23 |
Eagle43: Thanks for the feedback about 3D printing and casting.
How about lost wax casting? |
08-29-2021, 08:34 AM | #24 |
Thanks everyone for all of your input, I maybe Have a line on a replacement BUT the fight, thrifty-ness and the repairman in me STILL would like to SAVE it.
CharileNY - IF it’s okay can I call you??? I have an idea, my machinist can drill me some small holes for “pinning” it with some 1/32 or 1/16 roll pins both for lateral strength AND alignment BEFORE any welding or any kind of Epoxy type repair is attempted. 19Forty - Yes the exact pump and year you posted! Dean333 - Thank you for the potential Offer of your extra pump BUT I think IF your pump is in fact a 1934, it would be a completely different pump. Doesn’t your Mount to the oil filler tube on the side, same as 1935?? “OR” shouldn’t it?? Thanks for the thought and kind offer. I will keep all posted of my success (or failure) Thanks again everyone!! |
08-29-2021, 08:58 AM | #25 |
Robert,
My spin is to hi jack Ted's idea....I'd use .062 gauge stock whittled to the same shape as the base flange then flame 'toughen' to resist bending. The broken ear can be mimicked with a chunk of extruded aluminum (quite tough integrity wise) machined like a recess clamp that will trap a flat machined on the broken area.....I'm in the weeds now trying to articulate. Guess I'm better with a milling machine than English. Since the pump and stand are one I'd add a .062 disc in the p/r cup of the pump arm. Charlie ny |
08-29-2021, 09:18 AM | #26 |
08-29-2021, 10:16 PM | #27 |
