Old 11-15-2018, 07:38 AM   #1
jlking2010
Default Brake drum paint
I bought new cast iron drums for my '31 Vicki, what is best paint to use on them?. I assume heat is a factor.
jlking2010 is offline   Reply With Quote
Old 11-15-2018, 07:53 AM   #2
WHN
Default Re: Brake drum paint
I have used a good name brand black shake can paint.
Heat has not been a problem.
I check the drums after almost every long drive to see if I might have a brake hanging up.
Sometimes they are warm but never hot. Enjoy.
WHN is offline   Reply With Quote
Old 11-15-2018, 08:19 AM   #3
DJ S
DJ S's Avatar
I had my drums powder coated. After 2 years and 5,000 miles, they're holding up remarkably well.
DJ S is offline   Reply With Quote
Old 11-15-2018, 09:59 AM   #4
BillEbob
BillEbob's Avatar
I used a high temp engine paint - trust me, the brakes on MY Vicky DO get hot ��
I ordered the bands from Bert’s for these steel drums. Looking forward to getting engine repairs over with, then on to installing the brake drum bands.
BillEbob is offline   Reply With Quote
Old 11-15-2018, 10:04 AM   #5
Don Turley
Don Turley's Avatar
I use the high heat paint in rattle cans that is noted for painting barbecue grills.
Don Turley is offline   Reply With Quote
Old 11-15-2018, 10:16 AM   #6
Mel Gross
We recommend using a high temp paint that would be used for engines, brake calipers, or BBQ's. Use a gloss finish (not satin or flat) as a gloss finish helps to prevent brake and / or road dust from sticking to the surface. When washing wheels with soap / cleaner and water, hitting the drums with the water knocks off most of the dust.
Mel Gross is offline   Reply With Quote
Old 11-15-2018, 02:07 PM   #7
jwilliams81
jwilliams81's Avatar
This is what I have used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
