Old 08-17-2018, 12:24 PM   #1
Will N
Will N's Avatar
Default here are the symptoms, guess the cause
Here are the symptoms, guess the cause: Pre-ignition under load, running hot under load, decrease in power, rolling idle.
First to get it right wins. (You get nothing if you win, except satisfaction)
Will N is offline   Reply With Quote
Old 08-17-2018, 01:03 PM   #2
100IH
Default Re: here are the symptoms, guess the cause
Would rather comment on what you think is a logical plan of attack.
100IH is offline   Reply With Quote
Old 08-17-2018, 01:15 PM   #3
DJ S
DJ S's Avatar
Too advanced timing...
DJ S is offline   Reply With Quote
Old 08-17-2018, 01:16 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Timing WAY to FAST!
Bill Pinging
"THE ASSISTANT GURU OF STUFF"
Old 08-17-2018, 01:17 PM   #5
Benson
Benson's Avatar
Too much spark advance (19 degrees) like you get when using A distributor with Model B timing cover.
Lean carb will do it also.
Benson is offline   Reply With Quote
Old 08-17-2018, 01:49 PM   #6
Will N
Will N's Avatar
I'll add that the timing was fine. The car ran beautifully on the trip out, and started exhibiting the symptoms on the way home. I have found the cause, and I'm wondering if any of you fine fellas could hazard a guess to what I found.
Old 08-17-2018, 02:02 PM   #7
40 Deluxe
intake leak? Internal collapse in muffler?
Old 08-17-2018, 02:29 PM   #8
Will N
Will N's Avatar
Ok, I'll show my hand. I did a quick compression check by cranking over the engine by hand, and it sure felt like the compression was off on a couple cylinders. Pulled the head and sure'nuff, the head gasket had blown between 3 and 4.
Old 08-19-2018, 03:53 PM   #9
ronn
sounds like "miss direction" to me......
Old 08-19-2018, 04:02 PM   #10
30ccpickup
30ccpickup's Avatar
Wouldn't it be 4 and 3
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 08-20-2018, 01:18 PM   #11
nhusa
nhusa's Avatar
Only If your on the left side and your right handed.
If your on the right side and your left handed it would be 3 and 4
If your on the left side and your left handed it would also be 3 and 4
If your on the right side and your left handed you are in the wrong place.
If you are ambidextrous you have to count 1, 2, 3, 4 and subtract one from the last number to get the first number then add one to it to get the second number.
You could also count 1, 2, 3, 4 select the last number for the first one and then subtract one to get the second.
You could also say the it is the cylinder closest to the firewall and the one that is next to it.
Just Saying!
nhusa is offline   Reply With Quote
Old 08-20-2018, 02:19 PM   #12
Will N
Will N's Avatar
... and if we were counting down under in Australia, it would be between 1 & 2
Old 08-20-2018, 05:14 PM   #13
30ccpickup
30ccpickup's Avatar
Ford counts 1, 2, 4 , 3 from the right and the left just not forwords always backwards.
Old 08-21-2018, 05:45 AM   #14
old31
Curious, before you pulled the head did you do a compression check?
Thread Tools
Display Modes
