Old 04-14-2018, 11:01 AM   #1
Vintage Copper 47
Vintage Copper 47's Avatar
Default A good brand name flow thru electric fuel pump
Ok.. I know it's been discussed before, my buddy needs a new 6 volt, flow thru electric fuel pump. It's for a 1947 FORDOR sedan with v8. Any suggestions?.. I told him he should use that type and re-install his mechanical pump... We went to an event yesterday and he was having intermittent vapor lock because his fuel pump is getting tired...
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 04-14-2018, 11:14 AM   #2
Drbrown
Drbrown's Avatar
Default Re: A good brand name flow thru electric fuel pump
I have a 12 volt system and use an Airtex, which is a flow-thro design. I understand they make a 6 volt version. Like many I use it only for priming the carb. I recommend keeping (or replacing) the mechanical pump. I have a spare in my trunk, rebuilt by Charlie NY. I had a few instances with vapor lock and the electric pump did save the situation.
Drbrown is offline   Reply With Quote
Old 04-14-2018, 11:29 AM   #3
Vintage Copper 47
Thanks Doc Brown
WALT
Old 04-14-2018, 03:16 PM   #4
Graeme / New Zealand
Graeme / New Zealand's Avatar
If you get an Airtex one make sure you get the low pressure 6v one or you will have to install a regulator.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-14-2018, 03:26 PM   #5
40cpe
40cpe's Avatar
Airtex E8902 is the one you want. They are available from lots of places. Google it and find your deal.
Here is one vendor you can see the specs. https://www.summitracing.com/parts/a...iABEgKxvvD_BwE
40cpe is offline   Reply With Quote
Old 04-14-2018, 03:37 PM   #6
HDowse
HDowse's Avatar
Rock Auto carries the E8902 for $33.79, 6v.
https://www.rockauto.com/en/moreinfo...47&jsn=2&jsn=2
HDowse is offline   Reply With Quote
Old 04-14-2018, 11:26 PM   #7
I just found Rockauto recently to get some 6v + Tridon flasher units. Great people to deal with, competative price and good service. 8 days to get them to me in NZ...can't bitch about that.
GB
Old 04-15-2018, 04:43 AM   #8
dwick01
dwick01's Avatar
I just put the Airtrex E8902 on my '47 fordor v8. It's working perfectly, using it along with the stock fuel pump. I put it on a momentary toggle switch and just use it for starting after it sits for a few days and vapor lock.
dwick01 is offline   Reply With Quote
