Old 04-11-2017, 11:01 PM   #1
Vintage Copper 47
Vintage Copper 47's Avatar
Default Is an Overdrive avail for 1947 Sedan?
I was out on the freeway this weekend and was cruising along b/t 60-62 mph and my flathead six motor hummed just fine; but seemed to be in the mid to high range on the rpms.. just wondering if they made an overdrive for the 3 on a tree transmission.
Vintage Copper 47 is offline   Reply With Quote
Old 04-11-2017, 11:27 PM   #2
cas3
Default Re: Is an Overdrive avail for 1947 Sedan?
lots of things are possible. all except for a columbia rear would require major drive line mods. none are cheap. if you are a fabricator, theres the mitchel overdrive, the t5 trans, the old borg warner stuff, etc. all are expencive,
Old 04-11-2017, 11:34 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
The "factory" option is the columbia
Old 04-12-2017, 05:39 AM   #4
Bursonaw
Bursonaw's Avatar
The Columbia two speed rear axle was offered as an option. The installation is pretty much a straight bolt in process. It just takes some time as it is a complete disassembly of the rear end and reassembly with the overdrive components. If you can find original controls little or no modifications will be required. If you get aftermarket controls you will have to mount the control valve. I have installed two complete Columbia's, one in each of my cars. Not a weekend project or a cheep way to go, but well worth the effort.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 04-12-2017, 06:46 AM   #5
slowforty
slowforty's Avatar
I was discussing Overdrive and Two-speed rear ends the other day. Give that the average V-8 driver might drive 500 miles in a season. $500 to $2500 for an overdrive or Columbia
set-up, might be better spent on gas or other improvement for your car.
slowforty is offline   Reply With Quote
Old 04-12-2017, 09:44 AM   #6
TJ
TJ's Avatar
Check your rear end ratio. Look on the bottom rib of the rear end housing for two numbers. Divide the small number into the big number and that will give you the ratio. You may have 4.11s with a 6 cylinder. If you have 4.11s all you would need to do is change rear end gears to 3.78. Those gears are readily available and much cheaper than a Columbia or Mitchell overdrive. You might even find a complete rear end for $200-300.
Old 04-12-2017, 10:47 AM   #7
Kube
Kube's Avatar
I have to ask... "are the brakes authentic"?
Old 04-12-2017, 12:37 PM   #8
Vintage Copper 47
I upgraded to Lincoln "bendix" style brakes.. way worth the money.. this car, though not a daily driver, is a roadworthy vehicle that will be driven to events in Los Angeles, Riverside, and Ventura Counties and other areas within a 150 mile range. So yeah I will average at least 2000 miles a year.. My transmission needs some work & new motor mounts, my trans guy should be able to swap out the gears..
I will check to see if I have the taller gears.
Old 04-12-2017, 12:42 PM   #9
Vintage Copper 47
That option... getting 3;78 gears might be the way to go.. but getting a factory "Columbia" option would be fine.
Old 04-12-2017, 12:58 PM   #10
Ingram 33vicky
My 46 wagon is running a 3:78 with a Columbia. Very nice running about 60 - 65 on freeway. Major Columbia parts are available, the original controls are expensive. The mount for the controls on a flathead 6 are rare as hens teeth. Controls can be fabricated if you are not stuck on being "period correct" I have been very lucky to have all the period correct controls and have not seen another set.
Paul
Ingram 33vicky is offline   Reply With Quote
Old 04-12-2017, 01:02 PM   #11
mrtexas
mrtexas's Avatar
I recommend the Mitchell OD. Installs in an afternoon. You might have to modify your trunk floor. Call Mitchell and ask them. $2,500. My 36 and 41 woodies did not require floor mods.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 04-12-2017, 01:10 PM   #12
jake197000
I have 2 cars with correct columbias love em Mitchell is good too I just like the authenticness of a Columbia.
jake197000 is offline   Reply With Quote
Old 04-12-2017, 01:15 PM   #13
Vintage Copper 47
Thanks for all the input guys.. I am still playing catch-up with my cash flow after the holidays.. and most of my off duty work will be drying up soon.. so as soon as I get some more money saved up.. I will look into it! Thanks again.
WALT
Old 04-12-2017, 01:57 PM   #14
Kube
Kube's Avatar
"authenticness"?
Old 04-12-2017, 01:59 PM   #15
Kube
Kube's Avatar
WALT
Walt, When you are closer to pulling the proverbial trigger, let me know. I have complete and rebuilt Columbia's with all proper controls for your model and am quite certain I have the proper bracket for the 6 cylinder.
Old 04-14-2017, 06:44 PM   #16
Vintage Copper 47
Thanks Kube.. will do so...
Old 04-15-2017, 09:25 AM   #17
Ol' Ron
Ol' Ron's Avatar
I think The Mitchall is the way to go. The Columbia is nice but not as reliable, parts are scarce. Unfortunately, both are expensive. 3.54 gears would be the cheapest, but you might want to consider raising the CR, if you do anything.
Old 06-20-2017, 04:17 PM   #18
Vintage Copper 47
I crawled under today... the bottom rib of the diff housing has NO numbers.. if they were there, the have been "mashed" from driving over curbs or something.. basically it looks like there used to be something marked on the bottom rib.. but now.. indiscernible blob marks...
Any suggestions on where else these rear end ratio numbers may be?
WALT
Old 06-20-2017, 04:23 PM   #19
Jason in TX
Jason in TX's Avatar
FYI - Thrid gear is always 1 to 1 in a stock ford transmission. Switching to Lincoln gears or taller transmission gears give you longer time spent in 1st and 2nd gear. 3rd gear is like a stock Ford car.
No other numbers stamped anywhere for rear end ratio. You could pull the speedo gear housing, put a mark on the gear with a paint pen and have someone rotate the rear wheel while you watch under the car and say stop when you see the dot again. If it goes around 3.11 times, you have a 4.11 rear. If it goes around 3.78 times, you have a 3.78 rear.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 06-20-2017, 04:35 PM   #20
Vintage Copper 47
Ok... I guess that would work... I only want to know because I need to replace the speedo gear housing.. and the parts guy needs to know.. I could order one of each or pull the old one and compare?
WALT
"Old enough for the experience & too young to know better"
