05-12-2010, 12:59 PM | #1 |
TECH HELP: '53 3-Speed Overdrive Trans in a '40 Tudor????
Will the later ('53) overdrive 3-speed bolt up to the earlier motor('40)? If so how much modification is need in the mounting department?
If all of that is good, how do those trannys work? Are they manually or electrically actuated? Thanks! |
05-12-2010, 05:06 PM | #2 |
Re: TECH HELP: '53 3-Speed Overdrive Trans in a '40 Tudor????
Kirk, I've been asking question about the T-86 3 speed overdrive transmission on this thread
http://www.fordbarn.com/forum/showthread.php?t=304 and have been getting some info from the guys. Lee
Salt Is Good... Mk 9:50 Last edited by Grandadeo; 05-15-2010 at 11:00 PM. |
05-12-2010, 05:45 PM | #3 |
Not worth the grief, in my opinion. Send Mitchell a 2Tune and get a decent inline OD...
05-12-2010, 05:49 PM | #4 |
05-12-2010, 06:09 PM | #5 | |
A 2Tune is Brit for 2 Grand. Mine is the 36%, lever operated style. Brings out my inner Enzo, quite like driving a six speed - think 75 mph in 2nd gear. Always that "just right" gear for cornering & passing, plus I can now actually leave town in the '37... |
05-12-2010, 06:17 PM | #6 |
05-12-2010, 06:30 PM | #7 | |
05-12-2010, 07:01 PM | #8 |
Check out the article in the new Street Rodder about this subject.
05-12-2010, 07:07 PM | #9 |
Easy swap, take out the old torque tube and replace with the Mitchell. 4 hour job, either 26 or 36 % overdrive. Just put one in my 41, running SBC and early running gear, makes for a fun ride.
