11-04-2021, 01:34 PM | #1 |
Zenith carb
I have the threads in the bottom of zenith carburetor stripped. Not the one that goes all the way through to bolt together, the other one. What is the answer to get that to seal up? It is not a standard bolt as it has a hole in it. Is there a value in that hole? Can I use a longer bolt, without the hole??
11-04-2021, 01:53 PM | #2 |
Re: Zenith carb
Might be difficult to fix bad threads in the casting. I have unmatched bottom castings, and the parts houses were selling replacements.
11-04-2021, 01:54 PM | #3 |
Re: Zenith carb
Here is how I handle that situation.
http://www.santaanitaas.org/wp-conte...-boss-leak.pdf Tom REndy |
11-04-2021, 02:01 PM | #4 |
Re: Zenith carb
Can u send me a link to someone who sells replacement bottom casts?
11-04-2021, 02:19 PM | #5 |
Re: Zenith carb
If casting threads are very bad then Tom Endy's is the best solution ( other than a new casting!). Often the threads on the brass drain are very worn yet the casting threads not too bad in which case a new brass drain will solve the problem. Sometimes if casting threads are worn grinding the casting down a little will get a new brass drain onto decent threads to get grip.
11-04-2021, 03:10 PM | #6 |
Re: Zenith carb
11-04-2021, 03:41 PM | #7 |
Re: Zenith carb
Whats your location? Ill send you one! I have many extras ! The picture is all rebuilt float tested. As Tom Stated easy to fix with old screen plug!
www.whidbeymodelaclub.com |
11-04-2021, 05:00 PM | #8 |
Re: Zenith carb
Great Gary.. I will send you info in email... Gary F?
11-04-2021, 08:33 PM | #9 |
Re: Zenith carb
I have looked at Tom Endy solution and I went looking for that filter screen and cant find it.. I have seen them on cars, but cant see where to order.
11-04-2021, 08:36 PM | #10 |
Re: Zenith carb
11-04-2021, 08:40 PM | #11 |
Re: Zenith carb
11-04-2021, 09:03 PM | #12 |
Re: Zenith carb
Thank you much. I also updated my profile, to contact me. Don't you need to get rid of any of those Zenith 1 carbs?
11-04-2021, 09:38 PM | #13 |
Re: Zenith carb
... sorry wrong post
11-04-2021, 10:01 PM | #14 |
Re: Zenith carb
11-05-2021, 10:38 AM | #15 |
Re: Zenith carb
What is the thread size on the drain plug?
TIA
11-05-2021, 10:53 AM | #16 |
Re: Zenith carb
3/8 - 24 thread
11-05-2021, 11:48 AM | #17 |
Re: Zenith carb
Any issue with removing the jet? The hole is like 3/8 deep
11-05-2021, 07:03 PM | #18 |
Re: Zenith carb
Did you get it fixed??
11-06-2021, 02:12 PM | #19 |
Re: Zenith carb
No..tapped all out. But not good threads. This casing is hosed. What ya got u can ship me?
11-06-2021, 04:16 PM | #20 |
Re: Zenith carb
Ill send you a bottom Zenith 1 you will have to supply jets etc off your old one? Local club no help??
