09-11-2021, 06:13 AM | #1 |
1BA Cyl. Block Info
After reviewing the Ford drawings I can conclude the 1BA was produced both with and without the 8 seat rings throughout the production period. The last issue date I find for changes was 5 May 1952. Those were minor changes making main bearing cap bolts and washers of varying types "optional". The 1BA could have 4 configurations denoted as A-B-C and D. The A&B with seat rings and the C&D without seat rings.
What is not clear from my review is the vehicle type a specific configuration was assigned to. At this point I can only guess which vehicles received which type. |
09-11-2021, 06:36 AM | #2 |
Re: 1BA Cyl. Block Info
Very interesting. Thank you.
09-11-2021, 04:35 PM | #3 |
That certainly explains why I have found the 1BA blocks with and without the eight exhaust seat rings. Could it be Ford was experimenting with and without the seat rings by installing them in just about anything then let the users buying the vehicles become the testers? Discovering the results later if and when engines were returned for factory authorized rebuilds. Makes one wonder.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
09-29-2021, 12:01 PM | #4 |
Just to add a little more information for history's sake, I just went through the dates on my car, which was a late 1951 build. The original engine that I removed from the car 5 years ago since it was making a funny noise, has a build date stamped on the intake surface of June 22, 1951. The assembly date on the cowl data plate says the car itself was assembled on June 26, 1951. I have the original owners manual and invoice for the car. "Got car July 2, 1951" is written in pencil in the "NOTES" section of the owners manual and is also on the hand-written invoice. Interestingly, it has "8BA" cast in the valley.
The car was built a the St. Paul plant. |
09-29-2021, 06:24 PM | #5 |
Ronnieroadster
