12-04-2017, 05:29 PM | #1 |
Will moving the screw, retard timing on my 47?
I have the "G", 226 cu inch, SIX cylinder... It's been about a year and 3,000 miles I have put on the original stock motor.. I think I am getting "pre-detonation" at idle, the motor gives an occasion rattle noise at low rpms and runs rough, then smooths out at higher rpms.. I figure I need to adjust the points & give her a tune-up.. but in the meantime, can I move the screw up or down to retard the spark?.. it is a crab distributor.... The car sat for the last two months while I was getting the transmission rebuilt.
p.s. the engine will diesel (run on).. for a second at shut down Thanks, WALT
WALT "We sleep safe in our beds because rough men stand ready in the night to visit violence on those who would do us harm". "Old enough for the experience & too young to know better" |
12-04-2017, 06:27 PM | #2 |
Re: Will moving the screw, retard timing on my 47?
Screw up (clockwise) advances timing. Jack E/NJ
12-04-2017, 06:43 PM | #3 |
Maybe carbon build-up in the cylinders. There are various methods of softening it so it can be pushed out the exhaust. MMO, water injection.
12-04-2017, 06:58 PM | #4 |
The adjustment on the side is usually set with a timing fixture tool on the bench and then left alone. Points gap settings can also have an effect. Setting points to specs is usually the first thing then check the timing setting to get it all in sync. A steel rule can be used if following the procedure in the operator's manual or shop manual to check or adjust timing.
There may be something wrong with the advance flyweight unit or vacuum brake. It's best to check all that stuff for condition and smooth operation if you take the distributor off for service. |
12-04-2017, 07:10 PM | #5 | |
12-05-2017, 04:30 PM | #6 |
