Old 01-03-2021, 09:38 AM   #1
GregJac
Default 30 Coupe running too rich
I have a rebuilt carb on my car and I'm running much too rich.
I get nothing from either adjustment.
Timing checks out okay and consistent.
GregJac is offline   Reply With Quote
Old 01-03-2021, 12:37 PM   #2
700rpm
700rpm's Avatar
Default Re: 30 Coupe running too rich
Which adjustments are you referring to? Who rebuilt the carb, and what did that entail?
Ray Horton, Portland, OR
Old 01-03-2021, 12:44 PM   #3
Patrick L.
Patrick L.'s Avatar
Check float level.
Old 01-03-2021, 12:50 PM   #4
Gary WA
Gary WA's Avatar
When you rebuilt carb were all passages cleaned out! Jets properly done! and proper gaskets installed.
www.whidbeymodelaclub.com
Old 01-03-2021, 03:28 PM   #5
GregJac
The carb was purchased from Gaslight and rebuilt by Charlie Armstrong, in Kentucky.
moving the gas adjusting needle has little effect and the idle air screw does nothing. Screw in all the way in and no change.
Float level checks at 5/8" and fuel shut-off valve has been replaced. I also replaced the float valve with a Viton tipped one.
Old 01-03-2021, 04:25 PM   #6
wwirz
I had a similar issue and checked everything on the car as you did. It turned out to be the GAV. I replaced it...problem solved.
wwirz is offline   Reply With Quote
Old 01-03-2021, 04:53 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
How fast is your idle, when turning the idle air screw. It needs to be 450 rpm, or lower. Otherwise your no longer running on the idle circuit. If running low rpm and no change with idle air screw, then you have a air(vacuum) leak.
Old 01-03-2021, 07:26 PM   #8
nkaminar
nkaminar's Avatar
Are you using an air filter?
Old 01-04-2021, 12:26 PM   #9
Ed in Maine
Make sure your choke is getting wide open. If the GAV is full closed and still too rich, then most likely the Main Jet is over sized. Ask your rebuilder what the flow data was on your rebuild? The Main Jet should be 150 to 158 ml/min. (36 in. water column test).
Ed in Maine is offline   Reply With Quote
Old 01-04-2021, 02:49 PM   #10
Ernie Vitucci
Good afternoon...The Model did not come with an air filter...if you are running one...the car will usually run rich...it takes a change of Jets when rebuilding to compensate for the air filter...Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 01-04-2021, 04:32 PM   #11
Mulletwagon
Mulletwagon's Avatar
Also, confirm no vacuum leaks.
Mulletwagon is offline   Reply With Quote
