12-23-2020, 10:38 PM | #21 |
Re: Depth of threads for ratchet nut?
Wanted to close this discussion out for the benefit of future readers. I purchased a 1-1/4" bolt and was able to turn it all the way down into the bore on the crankshaft, so that thread depth is indeed the full 1-1/4". I took the bolt out and re-installed the outer pulley piece, with a light coat of synthetic grease around the I.D. and on the face that would contact the washer. I then installed the bolt with a hardened washer. I'm now able to use a 24" breaker bar and a cheap 15/16" socket from AutoZone to turn the engine in either direction. Very happy with the outcome.
12-23-2020, 11:29 PM | #22 |
How were you able to tighten the bolt (stopping the motor from turning) and did you torque it or by feel?
12-24-2020, 07:48 AM | #23 | |
My torque wrench only goes to 85, so I took it up to the max there and then used the breaker bar to go a bit further. With anti-seize on the threads, that should be plenty. |
