04-02-2020, 11:57 AM | #21 |
Re: Finding TDC for leak-down test
You will find that when the pistons are at TDC and BDC, the crank will turn back and forth a bit easily, not so when not on TDC
04-02-2020, 12:32 PM | #22 | |
https://en.wikipedia.org/wiki/Air-start_system |
04-02-2020, 08:15 PM | #23 | |
There is nothing restraining an aircraft propellor. The car is restrained. If the airplane prop is on top dead center when you apply the air pressure it will not move. |
04-02-2020, 08:53 PM | #24 |
If the engine gets away i doubt it will travel to BDC. At most just surprise those doing the testing and possibly cause physical harm. If you have exact TDC nothing should happen. I have done this many times alone and was able to leave the engine to listen at the tail pipe, Crankcase breather and radiator without problems.
04-02-2020, 09:58 PM | #25 |
No matter how fast the piston speed is,it stops twice for each crankshaft revolution..food for thought.
04-03-2020, 07:19 AM | #26 |
04-03-2020, 08:29 AM | #27 |
The engine will not move very far. I know from experience.
04-03-2020, 08:54 AM | #28 |
I would like to disagree with much of the information that suggests a cylinder does not have to be exactly at TDC to perform a leak-down test.
First, there are A) leak-down tests and then there are B) so-called leak down tests and then C) just air pressure tests, often of a single cylinder, that some erroneously call 'leak down tests'. Actual leak down tests were standardized for aircraft cylinder comparisons and evaluation with a 0.040" orifice and manifold and the entire assembly, including gauges, feed fittings and hoses is calibrated for a specific indicated flow rate drop. Those instruments are certified as to calibration and not chinese junk. Nice, but overkill for the casual user. Now, in the case of this thread the O.P. is only looking for a valve leak so yes, a hose of shop air through a single cylinder not exactly at TDC may give you an audible hiss, but that is NOT a true leak down test. That would be like calling a farmer-fix with bailing wire a factory authorized and certified procedure. OK, who cares and so what if I do either A,B, or C above not exactly at TDC?: First, all used engines develop a ridge above the top ring position. Only at true TDC is the top ring tightly pressed against that ridge which may result in intermittent ring cocking and contact loss resulting in leakage not seen 1/16" down. A cracked top compression ring may only show excessive loss at this position. Also, only at true TDC can you detect any interference problems with piston/ gasket/ head that may cause a piston to tilt and break ring seal. You only really need to do what you have to do to look for a specific fault, like a valve leak. But please do not refer to an un-metered pressurization of a single cylinder at any old position as a leak-down test. Call it what it is- a listen for some kinda hiss test. A true leak down test is quantitative, a hiss test qualitative at best. |
04-03-2020, 10:21 AM | #29 |
I have to agree. Having worked in Aviation for 50 years. On your A this is a good test for valve leakage. It can also verify blo-by and help find possible head gasket problems. Yes you can hear air in the radiator.
04-03-2020, 10:26 AM | #30 |
I have an OTC 5609 cylinder leak tester, and the plan was to go to TDC and use regulated airflow to find out not only where the leak is but how severe. This will help me determine the cost/benefit for attempting a repair. As seen in another current thread, replacing valve guides is not easy and I don't have any local resources to help me out.
04-03-2020, 10:50 AM | #31 | |
This is an air powered starter motor. The large stationary engines mentioned put air pressure directly into the cylinders to get the engine rotating; no starter motor is used. A lot of youtube videos show this. |
04-03-2020, 10:53 AM | #32 |
Have not done a leak down myself, have questions.
Instead of listening in the radiator, can you just overfill the radiator and look for coolant bubbles? Other causes besides a bad head gasket? If you hear hissing in the crank case, other causes than rings? Instead of listening, can you seal the breather tube with the palm of your hand to see if there is pressure from the air hooked up to the spark plug hole? Thanks. |
04-03-2020, 11:16 AM | #33 | |
04-03-2020, 11:53 AM | #34 |
Asking for info only, do not have a problem,. Would like to try it sometime this year as educating myself. Just exploring the possibilities.
04-03-2020, 12:25 PM | #35 |
You can fill the radiator if you want to deal with the mess. Do not hold your hand over the oil fill tube. You will force oil out the rear main. With experience you will be able to determine what is acceptable and what is not. The point is there is a lot of trouble shooting that you can do with a leak tester.
04-03-2020, 03:57 PM | #36 |
All that is needed for an 'A' engine is the 'hiss' test. Its still a leak test no matter how its looked at. You're looking to see/hear where the cylinder air is escaping and if its more than normal.
