Old 12-05-2019, 10:49 AM   #21
mike657894
mike657894's Avatar
Default Re: Vacuum testing to diagnose fast idle
poor compression should be fixed. burnt or bent valve. maybe get lucky and its a bad head gasket. For worn guides you would need to take out the valves mine bent on the way out so got a new set of old style nos for $30. the valves cant grow. seats can be lapped down. but someone willing to do that amount of lapping will probably correct stem length.
mike657894 is offline   Reply With Quote
Old 12-05-2019, 10:56 PM   #22
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
When you say loose valve guides, do you mean worn stem clearance, or not securely attached?
Old 12-06-2019, 04:01 PM   #23
1931 flamingo
1931 flamingo's Avatar
I would think worn stem clearance.
Paul in CT
Old 12-06-2019, 04:05 PM   #24
alexiskai
alexiskai's Avatar
Right, like the guides have worn away over time and now there's lateral movement as the valves go up and down, causing them to not perform as desired.
Edit: Wanted to share this response I got from a local "classic car restoration" shop when I emailed them to ask whether they would take on a Model A valve job:
if it’s that old and you do a valve job it normally blows bottom out
So... not gonna use those guys.
Old 12-06-2019, 07:11 PM   #25
Y-Blockhead
Y-Blockhead's Avatar
A stock Model A has ~65psi compression and bringing #2 up to specs is certainly not going to "blow the bottom out". I agree, find someone else...
Thread Tools
Display Modes
