09-15-2019, 09:27 AM | #1 |
Ever have your engine die at a stop light?
After months of hard work I thought I had things tuned up perty good. Then yesterday came along. Went to Wallymart and filled the car with groceries. I felt so confident nothing would happen, I bought everything on the wife's shopping list. Even the eggs. Drove around the parking lot to get to the "easy" exit, stopped at the stop sign and waited about a minute for a break in traffic. Then the engine simply died. No sputtering. No coughing. Taken by surprise by the event I uttered that famous line . . . "Oh Crap!". Started the engine and 5 seconds later it died again. The combination of words that followed would have made Shakespeare proud of me. After the second start everything appeared normal and l continued on my way. Of course the smile that once adorned my mug was gone. So, has anything like this happened to you?
09-15-2019, 09:53 AM | #2 |
Re: Ever have your engine die at a stop light?
Something simple!
I would wait and see if it happens again. You might want to check vent in gas cap. Enjoy. |
09-15-2019, 10:08 AM | #3 |
Didn't know about the vent hole. I can see it now. It was fine though. Thanks.
09-15-2019, 10:36 AM | #4 |
Sometimes hot weather can cause a lot of issues, as expressed in other threads. Gas line not sloping downward to carb to help prevent vapor lock, failing coil or condenser, debris in gas plugging carb filter or filter in gas tank, etc.
09-15-2019, 10:47 AM | #5 |
It Usually Happens to me when I forget to turn the gas back on!
09-15-2019, 11:44 AM | #6 |
09-15-2019, 12:04 PM | #7 |
That's a very good possibility. Another problem I am experiencing right now is that after I shut the car off fuel does leak out of the intake some. Which is something I read elsewhere as being a symptom of a float level problem.
09-15-2019, 12:04 PM | #8 |
Did it just simply die while idling or when you stepped on the throttle ?
Either way for now, I'd recommend re-adjusting/checking the idle mixture. Generally if the float is too high the engine will quit while coming to a stop. A vent issue usually raises its ugly head while cruising. But, its an 'A' so about anything is possible. |
09-15-2019, 12:35 PM | #9 |
Good Morning...Since it self corrected, you might have had a couple of air bubbles in your fuel line...sort of the beginning of fuel boiling or some such. What I have found is that when I come up to a stop my right fingers are always on the hand throttle and I usually increase the RPM just a bit as I take the car out of gear and coast up to a stop. Once all stopped, I ease the throttle lever up to the stop again. I've had 'A's since the 1960's and old timers then, used to tell me it was from fuel sloshing in the carburetor bowl! They taught me the sequence of coasting up to a stop or a light and adding a bit of hand throttle. It has served me well. Have a great Model A Day! Ernie in Arizona
09-15-2019, 01:22 PM | #10 | |
If you shut the gas valve off, and it eventually stops leaking, the shutoff is good and possibly your; float valve is bad, or float is bad, sometimes the float valve wears a spot into the mating area of the float which causes the float valve to not seat correctly, and a few other possibilities. If it is leaking and teh engine is warm/sitting, you are getting a pretty rich gas mixture the 1st minutes of the car running, might contribute to the stalling. If it continues to leak with the gas valve off, both your gas valve and carb have issues. Fix the carb, might solve the stalling. |
09-15-2019, 01:57 PM | #11 |
Float too high sometimes, Slosh makes a flood situation. Float level too low, goes so lean it dies. Try both.
09-15-2019, 02:06 PM | #12 |
Well, dismantled the carburetor which is a Xenith 2, a recent rebuild and the height of the float from the carburetor it said it 5/8 of an inch. Cleaned all the jets. The fuel leak is a slow dripping only occurs after you shut the car off and last a minute or so. This is the exact same problem I experienced with my tillison carburetor before I replaced it. I very well may add a shim under the bowl to lower it a tad in the future, should this become a serious problem.
09-15-2019, 06:42 PM | #13 | |
If you leaving the shutoff on, does it continue to drip? |
09-15-2019, 07:05 PM | #14 |
09-15-2019, 07:07 PM | #15 |
Having just gone out for a small trip to get the engine nice and hot, when I came back it didn't leak. That is odd. But having just opened the carburetor, and cleaning her out completely, maybe something changed. I'm sure the dripping will rear its ugly head again here, very shortly.
09-15-2019, 07:31 PM | #16 |
Turned on the shut-off valve and let her set for quite a while. She's not leaking. Ran my pinky finger up the air intake to the first jet. My finger came out dry. I may need to take her on a longer drive.
09-15-2019, 08:21 PM | #17 | |
I generally I try to do this also. Yesterday though, I am perty sure I didn't. Practice. I need more practice. |
09-15-2019, 09:08 PM | #18 |
Among the many improvements Ford made with the model B engine a new carb with a side mounted float was used..no effect from starting or stopping quickly,no touchy float adjustment,the float mounted port and starboard as opposed to the A's fore and aft design.
09-15-2019, 11:12 PM | #19 |
Could have been something as simple as something in the float valve, disassembling/cleaning may have fixed it.
09-16-2019, 12:10 AM | #20 |
There are three air-fuel circuits in the Zenith: one for low speed, one high speed and one for idle. The idle circuit is most critical when stopping for if the air-fuel passage is restricted or the idle not properly adjusted, the engine will die when pulling up to a stop.
Thread Tools | |
Display Modes | |
