Old 11-26-2018, 07:15 PM   #1
rockfallt
Default 8BA head studs leaking
What is the best sealant. I've used two different type of teflon sealer still no luck. Thanks
rockfallt is offline   Reply With Quote
Old 11-26-2018, 07:20 PM   #2
mfagan
mfagan's Avatar
Default Re: 8BA head studs leaking
Moroso liquid glass was recommended to me.
Marvin Fagan
214-697-8430
mfagan is offline   Reply With Quote
Old 11-26-2018, 07:42 PM   #3
JSeery
JSeery's Avatar
Are you really talking studs or are you using head bolts?
Old 11-26-2018, 07:57 PM   #4
Karl Wolf
Karl Wolf's Avatar
I would use non hardening Permatex.
Use it on the threads.
And into the block ahead of the studs/bolts.
Use a pencil or something to get it below the top of the threads.
Do one bolt at a time if you're already torqed up.
Karl
Karl Wolf is offline   Reply With Quote
Old 11-26-2018, 08:48 PM   #5
mtflat
mtflat's Avatar
I had that happen once when I flipped a gasket over by mistake. Starting over with a fresh head gasket solved the weeping around the bolts.
mtflat is offline   Reply With Quote
Old 11-27-2018, 11:43 AM   #6
Byron Warwick
Byron Warwick's Avatar
I like Karl Wolf's suggestion of removing on bolt at a time. Are there any bolts that go into a water jacket. That would mean draining the coolant. Is that correct?
Cheers, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 11-27-2018, 11:52 AM   #7
marko39
Cheers, Byron.
most of the bolts go into water jacket. you would have to drain some coolant and i would want bolts and thier holes clean abd dry before using any sealant. Mark
marko39 is offline   Reply With Quote
Old 11-27-2018, 11:54 AM   #8
GreenMonster48
GreenMonster48's Avatar
I do 2 or 3 at a time until I've got all 24 on a side done. Make sure you drain the coolant out and that the threads are dry or else it wont seal properly. Use a liberal amount of Permatex #2 and wipe away the excess then let them dry at least 24 hours.
GreenMonster48 is offline   Reply With Quote
Old 11-27-2018, 12:06 PM   #9
GOSFAST
GOSFAST's Avatar
Just about every studded build here gets Permatex #1 (hard-setting), Chevy's OR Flatheads.
Have never experienced any stud leaks using this sealer, and we've dynoed hundreds upon hundreds of units!
Thanks, Gary in N.Y.
P.S. Having said that above here I would add this, do not install any anti-freeze until you've established there are no leaks with plain water. The anti-freeze will impede sealing any small leaks if they should occur? Be wary of the ambient temps though, you don't want any freeze-ups.
GOSFAST is offline   Reply With Quote
Old 11-27-2018, 07:10 PM   #10
rockfallt
Thank you all for the info
