04-11-2018, 01:37 PM | #1 |
Removing upper radiator hose
All I wanted to do is install a pair of Robert Shewman's thermostats. Easy job. Right? well not if you can't remove the upper end of the hose from the radiator. It seems that I need to remove the entire hose but the bottom end is stuck to the water pump.
Any ideas other than cutting the hoses and installing new ones? |
04-11-2018, 02:08 PM | #2 |
Re: Removing upper radiator hose
They make a special tool for that; it looks like an awl with the last 1 inch or so bent at a 90° angle. They're not a perfect solution, but they work in most caes.
04-11-2018, 02:23 PM | #3 |
04-11-2018, 03:23 PM | #4 |
I usually take an arc joint pliers and try to twist the hose to loosen it.
04-11-2018, 03:46 PM | #5 |
If you can open up one point on the hose to water pump, spray some PB blaster or WD40 in and let it work a bit. Open up a little more, more spray, etc. and you can probably get it off with a little prying and twisting on the hose.
04-12-2018, 08:54 AM | #6 | |
Petehoovie has posted a photo of one.
04-12-2018, 03:23 PM | #7 |
Great for window gaskets.
Bruce
Works good Lasts long time |
Thread Tools | |
Display Modes | |
