Old 03-12-2018, 03:19 AM   #1
Jeff M
Default USA Light Switch
I've seen conflicting things on the new reproduction switch. What all is exactly needed to get it working correctly? I have a new harness from Bratton's and a new USA switch. I've heard to modify the harness disc, or sand down the metal housing on the switch. Who all is running this setup and what was your experience of getting it to work smoothy?
Jeff M is offline   Reply With Quote
Old 03-12-2018, 07:51 AM   #2
JDupuis
JDupuis's Avatar
Default Re: USA Light Switch
Hey Jeff, Assemble the harness and switch, and place on the end of the steering column, before running the wires through the frame. Does the light switch move easily, or at all?
Chances are, you may not have any problem.
In the past, I had to file down a new harness wafer/disc as it was thicker then the original, being used in an original switch. Good Luck.
Keep us informed of your findings. Jeff D
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 03-12-2018, 03:58 PM   #3
Smooth_One
Smooth_One's Avatar
I'm buying a new USA switch this week and I already have a new harness.
Keep us posted.
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 03-12-2018, 08:48 PM   #4
Jeff M
Thanks for the replies, I'll probably install them both later this week.
Old 03-13-2018, 02:18 PM   #5
hardtimes
hardtimes's Avatar
Hey Jeff,
When I put mine together and after trial assembly/fitment checks, I put a small dab of 'dielectric grease' on each contact. End product works great !
hardtimes is offline   Reply With Quote
Old 03-13-2018, 07:35 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by hardtimes View Post
Hey Jeff,
Good Tip.
Old 03-13-2018, 09:48 PM   #7
Jeff M
Hey Jeff,
Great idea, was yours the new repro switch?
Old 03-14-2018, 07:33 PM   #8
1930marie
1930marie's Avatar
Hey Jeff,
great tip! and I thought I was just starting to have a model A figured out and the old dog here learns a new trick! lol Awesome!
They know enough who know to learn.
1930marie is offline   Reply With Quote
