06-20-2017, 06:40 PM | #1 |
Educate me on distributor
If you have a hairline crack in top of distributor body and replace upper bearing/bushing what problem would crack cause? Wouldn't the bearing prevent the crack from opening any further and causing a wobble? And yes I have one with a crack.
06-20-2017, 06:47 PM | #2 |
Re: Educate me on distributor
When you ream the new bushing the crack will probably allow the bushing to turn and not ream.
06-20-2017, 06:57 PM | #3 |
Here is a link to Tom Endy's article on the crack.
http://www.santaanitaas.org/wp-conte...l-Aug-2013.pdf Bob |
06-20-2017, 08:24 PM | #4 |
I think a drop of loctite will stop that.
06-20-2017, 11:07 PM | #5 |
A crack in the distributor where it supports a bushing could allow the bushing to wallow around as the shaft rotates.
Tom Endy |
06-21-2017, 12:49 AM | #6 |
06-21-2017, 05:41 AM | #7 |
Housings are plentiful. Get another
