Old 08-17-2016, 04:18 PM   #1
art ebeling
art ebeling's Avatar
Default Brumfield head gasket
Last spring I put a new head gasket on my engine with the 5.9 Brumfield head. I had the head off searching for a noise that ended up being a metal timing gear. I used the fel pro 7013 as recommended by Larry Brumfield with new studs and nuts and copper spray, and a half tube of radiator sealer. I retorqued the head four times and did not have any leaks, but after the engine and drivetrain have been sitting for about four months waiting on body work, I am getting a weep of coolant down the left side of the engine. Should I retorque the head or replace the gasket again? Will the Best brand gasket work with the Brumfield head and should I use new studs and nuts again? Thanks, Art
art ebeling is offline   Reply With Quote
Old 08-17-2016, 07:26 PM   #2
Dan/Kzo
Dan/Kzo's Avatar
Default Re: Brumfield head gasket
I am 6 or 7 years on a Best 509G with a Brumfield 5.9
Dan/Kzo is offline   Reply With Quote
