Old 10-23-2015, 05:33 PM   #41
ron103140
Default Re: Engine locked up
I pulled the plugs first to find number 3 cylinder full of water. Drained the water (a lot ) and oil from pan, removed the head ( a lot more water) to chech gasket and head. Gasket seemed ok but the (C) head had previously been repaired. Brazed nearly all the way across the center. Nice job but I feel it's where the problem is. I have decided to get a new 5.5 to 1 from Snyders along with a gasket. Thanks for all the help guys. Ron
ron103140 is offline   Reply With Quote
Old 10-23-2015, 07:51 PM   #42
tbirdtbird
wise move
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-23-2015, 09:54 PM   #43
Henry's Lady's Man
Henry's Lady's Man's Avatar
I'd never heard of hydrolock before... in other words, it never happened to me or anyone I knew. So I plead ignorance. Ain't the Ford Barn great?
... prosperity is not the product of charity but of industry - HENRY FORD
Henry's Lady's Man is offline   Reply With Quote
Old 10-23-2015, 10:28 PM   #44
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by ron103140 View Post
Well I tried the easy way first. Removed the plugs and found number 3 was full of water. Next I drained a lot of water and the oil from pan. Removed head and got all water out of the intake and pistons. This is a "c" head and I see some brazing thats been done close to the center bolt hole. My questions are, do I need to remove the pan and clean any water that may be in the baffle or just add oil and run a little and change the oil? Do I need to have the head cleaned and magnifluxed for possable leak? I ordered a new head gasket when I installed the head and wander if I got an incorrect one as I didn't let supplier know I had a "c" head. Again any help will be great. Ron
That's the reason I asked you to do that days ago.
Remove the pan and drain everything out. the little water that remains in the nooks and crannies will not be a problem. Now is the time to access the purchase of a new head and you have chosen wisely.
Old 10-24-2015, 05:11 AM   #45
Mitch//pa
An engine can also hydro lock from to much fuel (carb flooding) but less prone to happen on an up draft manifold as most of the fuel will run out.
