Old 07-22-2015, 07:40 PM   #1
Benson
Benson's Avatar
Default How do rear axle threads get Damaged????
removed
Benson is offline   Reply With Quote
Old 07-22-2015, 09:12 PM   #2
Ron in Quincy
Ron in Quincy's Avatar
Default Re: How do rear axle threads get Damaged????
The original rear castle nut is a special hardened nut, 5/8-18. If a person uses a 5/8-18 butter nut and attempts to torque it to 90 pounds you will damage the threads on the axel.
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-23-2015, 09:15 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Torquing a tapered joint over 50 lbs-ft is not a good thing to do as it may cause deformation. If the axle and hub are in good condition, the shear key takes the driveline torque and the taper centers the axle. The taper only needs to be snug for a line fit.
Bob Bidonde
Old 07-23-2015, 03:47 PM   #4
Larry Jenkins
Then why is the original spec 100 foot pounds?
Your statement makes sense.
Larry
Larry Jenkins is offline   Reply With Quote
Old 07-23-2015, 05:35 PM   #5
Ron in Quincy
That is why I torque to 90 pounds, then tighten just enough to insert the cotter key. Drums not torqued to at least 90 pounds can cause another problem like wearing the axel key. It may take several times to get a proper drum fit. If the drum rubs the backing plate you may have to shim the axel to get proper fit, Also the service brake shoes may rub the inside of the drum. For every thing to work properly all thing have to be considered when assembling the rear drums. Also arcing the service brake shoes in each rear and front drum is important for good brakes. The mechanical brake system on the A is designed for 60 percent braking on the rear and 40 percent on the front.
Ron
