Old 09-07-2020, 03:57 PM   #1
norcalal
Default 1935 Ford truck radiator fan
I have a 1935 Ford BB big Truck with a Chevy V8 and original style radiator and grille. What is the best fan system to install to keep her cool?
norcalal is offline   Reply With Quote
Old 09-07-2020, 08:40 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 1935 Ford truck radiator fan
I would use a standard engine mounted fan if there is clearance between the engine and the radiator.
Zeke3 is offline   Reply With Quote
Old 09-07-2020, 11:21 PM   #3
norcalal
That would be way too low. Someone has made this switch before and must know what works best. I assume an electric fan and shroud is the way to go.
Old 09-07-2020, 11:59 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Forget that electric fan. Even if you do find a GOOD one, they draw a hell of A LOT of current, they look like an afterthought, and everyone else will snicker about it behind your back. Look-up "Zip" brand 'water pump riser' that raises the fan approximately five inches. Speedway motors carries them, for which you can click on the link just below. The second link is of more detailed pictures. DD
https://www.speedwaymotors.com/Zips-...n=bingshopping
https://www.jalopyjournal.com/forum/...-pump.1152694/
Click Links Below __
T5 W/TORQUE TUBE
Old 09-09-2020, 04:02 PM   #5
norcalal
Thank you coopman, Certainly looks like the way to go, and would love to hear from anyone who has has first hand experience! Thanks, Guys
Old 09-09-2020, 06:03 PM   #6
Lawson Cox
Lawson Cox's Avatar
I have a correct generator mounted fan for a stock 35 ford truck, but don't know if it would work with your setup.
