06-01-2020, 09:18 PM | #1 |
Universal Joint Removal
So I just started taking apart my three-speed Ford toploader transmission and I cannot figure out, for the life of me, how to remove the universal joint from the back of the transmission. Can anyone advise me if I am missing something?
06-01-2020, 09:20 PM | #2 |
Re: Universal Joint Removal
It is bolted on.
06-01-2020, 09:26 PM | #3 |
I have removed the bolt, but it won't come off. Figured there was something else I was missing.
06-01-2020, 09:41 PM | #4 |
It's stuck! With the bolt out, pry it off! DD
06-01-2020, 11:06 PM | #5 |
Little heat and she popped right off. For the clutch shaft removal, do you grind off the clutch fork pin and slide the shaft out?
06-01-2020, 11:47 PM | #6 | |
Yup! Grind the head and punch the pin out! DD |
06-02-2020, 05:12 AM | #7 |
Be suree to save the special Thick washer that heldd thee U joint on, See previous posts on this. JMS kerk
06-02-2020, 12:48 PM | #8 |
If laying rusty, penetrant, and a little torment with a hammer, take your time you're not sticking a nail into wood. Give the oil time to creep into the rust. Good luck. Welcome Neighbor.
Enjoy yer day. Tom Hate can't fix what it started. |
06-02-2020, 05:23 PM | #9 |
Get the book, from the master Mac Van Pelt. Everything you need to know.
http://www.vanpeltsales.com/FH_web/f...trans-book.htm |
