Old 12-09-2017, 01:03 PM   #1
raisinhel
raisinhel's Avatar
Default lets see your winter front grill.
ive seen some nice ones and some of you have a few.
raisinhel is offline   Reply With Quote
Old 12-09-2017, 01:06 PM   #2
RalphG
RalphG's Avatar
Default Re: lets see your winter front grill.
Yes, mines real fancy. A piece of cardboard but I don't have a picture of it. :-)
RalphG is offline   Reply With Quote
Old 12-09-2017, 06:26 PM   #3
Terranova
Mines stashed in the overhead cabinets, still wanna see it?
Terranova is offline   Reply With Quote
Old 12-09-2017, 06:51 PM   #4
carguybill
carguybill's Avatar
So, does a winter grill cover do an effective job of increasing the engine operating temperture? Is it necessary if thermostats are installed?
carguybill is offline   Reply With Quote
Old 12-09-2017, 07:31 PM   #5
zeffer1940
zeffer1940's Avatar
No stats, these do help,and can cause overheating found out.......Kinda Cool.
zeffer1940 is offline   Reply With Quote
Old 12-09-2017, 08:10 PM   #6
RalphG
RalphG's Avatar
Yes, it makes a big difference to heating up an engine. In fact I had to roll the cardboard down some on the Merc when I took it out for the first snow drive in early November. Heat gauge was higher than I saw it in the heat of July.
Cardboard up front of the grille or against the radiator was standard winter driving technique here before the fancy, store bought winter fronts were available.
Old 12-09-2017, 08:25 PM   #7
Angledrive
Angledrive's Avatar
I couldn't resist
Angledrive is offline   Reply With Quote
Old 12-09-2017, 08:39 PM   #8
tubman
tubman's Avatar
And you're in Florida?
Old 12-10-2017, 08:44 AM   #9
Angledrive
Angledrive's Avatar
Denny, That pic was taken January 1961 in Westborough, MA. Roadster was entered in show in Boston and driven back but not put in garage. Weather forecasting was not very good back then, hence the reason I live in Florida. By the way it was 36 degrees here this morning.
Old 12-10-2017, 09:11 AM   #10
Pat/Ohio
Pat/Ohio's Avatar
Angledrive.....I hope it warms up down there before I arrive right after Christmas! Suppose to play softball at SouthWest Complex the first week in January. Pat
Pat/Ohio is offline   Reply With Quote
Old 12-10-2017, 09:30 AM   #11
Angledrive
Angledrive's Avatar
Bring some warm clothes just in case.
Old 12-10-2017, 11:54 AM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
Here's the front of my car in the winter, but without a winter front grille . I don't drive during the winter once the roads are covered with salt, as they are right now.
The second picture doesn't show a winter front grille either, but with that rig it should probably have one
File Type: jpg '35 standard fordor sedan Feb. 18, 2015 (2).jpg (68.8 KB, 59 views)
John
Old 12-10-2017, 01:13 PM   #13
5851a
Neither snow nor rain nor heat nor gloom of night stays these couriers from the swift completion of their appointed rounds.
5851a is offline   Reply With Quote
Old 12-10-2017, 01:21 PM   #14
grovesmr
Not for my truck, not even for an early v8. Looks a little small for a 28/9 model a. But it's pretty cool. If the mechanism was modified for a cable operation it'd be really cool
grovesmr is offline   Reply With Quote
Old 12-10-2017, 01:24 PM   #15
skidmarks
skidmarks's Avatar
Got some early season snow last night
skidmarks is offline   Reply With Quote
Old 12-10-2017, 02:06 PM   #16
RalphG
RalphG's Avatar
Working around the Merc this morning and remembered this thread about winter fronts. So here is mine. Nothing fancy. Just a piece of John Deere cardboard. Actually a piece of carpet is more desirable as it is not so hard on the radiator fins.
Old 12-10-2017, 10:36 PM   #17
Darrell S
Darrell S's Avatar
I once owned a 41 Cadillac that had louvers in front of the radiator controlled by a thermostat. Cold they closed, opened when warm.
Darrell S is offline   Reply With Quote
Old 12-11-2017, 07:02 AM   #18
51 MERC-CT
51 MERC-CT's Avatar
Here's mine.
Old 12-11-2017, 01:26 PM   #19
blucar
blucar's Avatar
From my point of view thermostats are a must have item for all year driving.. I think 160's are ok but 180's are better.. When you calculate the wind chill factor on a cold winter day the coolant in the radiator can freeze. I have had that happen, could not figure out why the heater was blowing cold air. It took me awhile to wake up to what was going on. I have a silver colored cloth type of winter front for my '36 that clips onto the grille. Pretty handy, it can be folded up and stored in the trunk..
Bill.... 36 5 win cpe
blucar is offline   Reply With Quote
Old 12-11-2017, 07:21 PM   #20
51 MERC-CT
51 MERC-CT's Avatar
Always thought that "wind chill factor" applies to the effects on human skin.
