Old 12-06-2020, 11:59 AM   #1
Blindhuckster
Blindhuckster's Avatar
Default 37 Deluxe Coupe Seat Glide Problem
Trying to resolve an issue with the bench seat glides on my coupe. The seat adjuster position lock will not hold. I have them lubed up good and they slide great. When I try and engage the lock, it acts like it wants to catch on the drivers side only, but will not hold. The fabric wrapped springs are attached on both glides, but it seems to me, that I must be missing some critical part. There is no rod (which I would assume there should be to transfer the lock action from one glide to the other side. I have attached a picture of the drivers side glide. I have search the net for picture of the lock function, but come up empty. Any help would be appreciated. Thanks Nate Anello
Blindhuckster is offline   Reply With Quote
Old 12-06-2020, 12:05 PM   #2
rich b
rich b's Avatar
Default Re: 37 Deluxe Coupe Seat Glide Problem
Don't know if your '37 is the same; but my '40 has a straight rod that goes side to side.
The ends go in a hole similar to the one in your seat track.
There are gears on the rod that engage the notches in the seat track; effectively keeping the tracks in sync.
rich b is offline   Reply With Quote
Old 12-06-2020, 12:16 PM   #3
DavidG
DavidG's Avatar
A similar rod was used on '37 adjustable seats as well.
Old 12-06-2020, 12:56 PM   #4
Blindhuckster
So does anyone have that parts needed to correct this issue (rod and gears) that you would be willing to sell? Thanks Nate Anello
Old 12-06-2020, 03:39 PM   #5
1937sedandelivery
I don't have any spare parts, but here are some pics of my 37 bench seat.
gregg
1937sedandelivery is offline   Reply With Quote
Old 12-06-2020, 03:58 PM   #6
Blindhuckster
Gregg, Thanks so much for sending those. That is very helpful. I did find a listing for a rod with the gears on eBay for a 1947. Rod width is too wide, but thinking I can cut it down and weld it back up for the correct width. Just confirming with seller the rod diameter is 3/8". Thanks Nate
Old 12-06-2020, 05:19 PM   #7
Zeke3
Zeke3's Avatar
Yes, the rod diameter is 3/8". Gregg's seat looks much better than mine. The length of the rod is around 36" and it has two 10 tooth gears on it that are about 1" in diameter. I think you could make one if necessary.
Zeke3 is offline   Reply With Quote
Old 12-06-2020, 05:44 PM   #8
Blindhuckster
You guys are awesome. Thank you some much to taking the time to take and upload pictures to help a guy out. Nate
Old 12-06-2020, 08:51 PM   #9
35fordtn
35fordtn's Avatar
Nate I have a NOS Rod, but trying to find it will be the struggle.
35fordtn is offline   Reply With Quote
Old 12-06-2020, 09:33 PM   #10
Blindhuckster
I know that your super busy running your parts business. If you get a chance to look for the rod and locate it, I'd gladly purchase it. I'll hold off on the Ebay seller for now. I sent you a private message as well Nate Anello
