Old 07-14-2018, 02:12 PM   #1
Dan 1939
Dan 1939's Avatar
Default Oil Dip Stick and tube 8BA or 8RT ??
I have a 1953 Flathead V8 in my 1939 pick-up. It has a truck oil pan. The dipstick is marked 8BA. It was suggested that I need a 8RT Dipstick.
My question is are the dipstick tubes the same length?
I think that if tube length is different it will effect the oil measurement.
Thanks, Dan
Dan 1939 is offline   Reply With Quote
Old 07-14-2018, 03:24 PM   #2
leon bee
Default Re: Oil Dip Stick and tube 8BA or 8RT ??
I've just done what was logical, and I think everyone else here would, too. Fill her with 5 quarts and run for a bit. Let her sit a few minutes then file a mark on the dipstick.
leon bee is offline   Reply With Quote
Old 07-14-2018, 03:26 PM   #3
leon bee
Except now I realize I don't know if trucks used 5 quarts. I'd check that first.
Old 07-14-2018, 04:16 PM   #4
flatjack9
flatjack9's Avatar
The tubes are the same length - 8 21/64". The 8BA dipstick is around 15 1/2" and I think the 8RT is around 14".
Old 07-14-2018, 04:26 PM   #5
George/Maine
George/Maine's Avatar
I was quires about the 8rt and 8ba.
The 8ba is shorter and the 8rt dip stick is 17" long.
I think I just added 5 quart and didn't check it , just now checked was down about 1 quart.
George/Maine is offline   Reply With Quote
Old 07-14-2018, 04:54 PM   #6
flatjack9
flatjack9's Avatar
I have a dipstick with 8BA stamped on it and it measures 15 1/2". I have an engine on the test stand with a truck pan and the dipstick measures around 14". With 5 qts in the pan, the level is at the full mark. The stick has no ID stamped on it.
Old 07-14-2018, 05:10 PM   #7
rotorwrench
rotorwrench's Avatar
The trucks (8RT) had kind of a deep pan. The 8RT-6750-B I have is 17 7/8" long OAL. They changed in 53 to the 8RC-6750-A and those are 20 23/64" long. The tube P/N 48-6754-B was used a long time and it is 8 21/64" long. The 1953 engines with the new pan had P/N 8RT-6784-A tube and it is 10" long.
Most of the dip sticks have the part number prefix on them. The 8BA-6750-A was used on all the center sump pans for Ford cars and including the 52 & 53 Mercury and it was listed at 18 15/32" long. Mercury rear sump pans used the 8CM-6750-B dip stick at 19 5/8" so it's all about the type of pan that is used as to the length of the dip stick.
I think Ford used overall length to measure. And some folks us tube stop to tip. Ford put those lengths in some of their parts catalogs but not all.
Old 07-14-2018, 05:18 PM   #8
flatjack9
flatjack9's Avatar
My dimensions were from the stop.
Old 07-14-2018, 06:05 PM   #9
George/Maine
I think that I should have measured for the stop to full mark Not the length.
So how many quarts for a 8rt for 1953
Old 07-14-2018, 06:29 PM   #10
rotorwrench
Fabricating a new stick would be the easiest way. The original poster mentioned the 1953 motor with a truck pan so I don't know if it is a 1953 truck pan or earlier 8RT set up. The 1953 F series pan was known as the stepped pan and has a large volume. It doesn't look like any of the other pans. It has a rear sump but the sump is still relatively deep even with the steps gradually making it shallower all the way up to the front. If it had the 8RT truck type pan with the clean out then he just needs the 8RT stick to be correct as long as his dip stick tube is 8 21/64" long. Ford was pretty good about marking there sticks. They should have 8RT on them somewhere if the engine uses that pan.
Old 07-15-2018, 10:28 AM   #11
19Fordy
19Fordy's Avatar
Here's an interesting 'oil debate fill" question with answers on HAMB.
https://www.jalopyjournal.com/forum/...-level.463488/
My 8BA with 50 merc oil pan and no filter takes 5 quarts and the dip stick shows FULL.
Old 07-15-2018, 12:04 PM   #12
rotorwrench
The filter housing does hold some oil since it has a bit of a standpipe effect on the return side. If the filter housing is empty due to cleaning & filter replacement, the dip stick should read full with 5-quarts just poured in the sump. After it is started and warmed up it may give a lower reading even after the drain back from the filter occurs. I have no idea what the dip stick will read but it likely won't read full. Now after it is topped off again, it should read full after a warm up run. It may take a while for the complete drain back from the filter to occur but with warmed up oil it shouldn't be too long.
Most if not all 8BA family engines have a filter assembly. It may be that this was calculated in when they mention 5-quart capacity. I'll have to check again at the next oil change on my Mercury cars.
Old 07-15-2018, 03:51 PM   #13
4t8v8
I've had to fabricate a number of dipsticks after engine conversions. This method works great. My 8RT requires 5 qts.
4t8v8 is offline   Reply With Quote
Old 07-16-2018, 05:52 PM   #14
Dan 1939
Dan 1939's Avatar
Thank you all for your help.
The dip stick tube measured 10" so my engine is has the new type pan mentioned by rotorwrench.
Does this mean I should be using 8RT dip stick?
Thanks again,
Dan
Old 07-16-2018, 06:02 PM   #15
George/Maine
I have the stepped pan and I think my dip stick is for a 1953.
I think if you were to fill with 5 quarts the 8BA would read 1/4" from bottom.
It would be way over with the stick in pic 5.
If you put 5 quarts that's good.
