Old 11-25-2017, 07:49 PM   #1
Dave1931Pickup
Default Speedometer Decals
Hi everyone, I'm starting to restore my 1931 Stewart Warner Speedometer. Brattons sells the number decals as the soak in water, slide off and adhere to the odometer wheels or speedometer surface like we did when we were kids building models. Snyders sells vinyl decals with adhesive back for sticking on the speedometer surface and odometer wheels. Which style is better and more authentic looking?
Thanks, Dave
Dave1931Pickup is offline   Reply With Quote
Old 11-25-2017, 08:50 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Speedometer Decals
Good question, and I don't know the answer. I wish someone would paint them, as original.
Old 11-25-2017, 09:01 PM   #3
duke36
Yes, good question. I have both kinds and the vinyl may be easier to install because the water slide may tear easily and turn yellow over time. Some of the new vinyl decals go on with water to help with positioning so check with your vendor.
duke36 is offline   Reply With Quote
Old 11-26-2017, 07:09 AM   #4
springerpete
springerpete's Avatar
Who is the guru for rebuilding speedometers ? I'd ask them.
springerpete is offline   Reply With Quote
Old 11-26-2017, 08:17 AM   #5
JDupuis
JDupuis's Avatar
Get ahold of Papanick.
JDupuis is offline   Reply With Quote
Old 11-26-2017, 12:24 PM   #6
Mark in MT
I personally prefer the water transfer decals over the vinyl. They are thinner, and allow slight realignment while applying to make sure that they are on straight. Mine are so thin that you can't see the split line where the ends overlap. I have had to glue the ends of vinyl ones sometimes to get them to lay down. Only done a thousand or so, still don't get every one right, why I buy decals 500 at a time.
My $.02
Mark in MT
Always looking for another opportunity to be wrong.
Mark in MT is offline   Reply With Quote
Old 11-26-2017, 06:43 PM   #7
papanick
Hay I use the stick on most of the time. With the water kind the (0) on the mile wheels don't mach the speed wheel. And the water kind are very hard to get them to lay flat. But it is all up to the guy that is rebuilding the speedometer. Any with the S/W round most of them are stick on now. But for the Waltham round they are water kind. Hope this helps. papanick
papanick is offline   Reply With Quote
Old 11-26-2017, 06:49 PM   #8
papanick
Dave if you run in to a hard time email me at [email protected] and we will see with we can do. papanick.
Old 12-13-2017, 05:36 PM   #9
papanick
Hay Dave I'm VERY happy you liked your speedometer. papanick
Old 12-13-2017, 08:14 PM   #10
Jim M
Jim M's Avatar
Another thanks to papanick. Mine came out wonderful! I was going to call him to ask if he would email me the tracking number and the darn thing got back before I got the chance to ask!!!
Jim M is offline   Reply With Quote
Old 12-13-2017, 08:52 PM   #11
CarlG
CarlG's Avatar
PapaNick rocks!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-14-2017, 10:02 AM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If you can still read the original numbers, JIST LEAVE THEM ALONE, or you'll be SOOOOOORY!!!
Bill Allthumbs
"THE ASSISTANT GURU OF STUFF"
Old 12-14-2017, 10:43 AM   #13
papanick
Most of the one's I have seen the numbers are very bad and you can not make them out any more. But if the numbers are good then just have it serviced.
Thread Tools
Display Modes
